Best twin turbo kit for LB7 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 26 (permalink) Old 05-24-2009, 08:33 AM Thread Starter
Send a message via AIM to dekocards90
What is the best twin turbo kit for an LB7, also, I was told I have to modify the position of the dual cp3 to fit it?
dekocards90 is offline
post #2 of 26 (permalink) Old 05-24-2009, 09:24 AM
Banned
People have seen good luck with the MPI kits from Nathan at maximized performance.
Ive seen a 11.80 on a ex cab lb7 with his kit.
Hondarider552 is offline
post #3 of 26 (permalink) Old 05-24-2009, 09:39 AM
Durallymax's Avatar
Yes MPIs kit is top notch. Itsa very very nice kit. Its proven well putting stock motor trucks in the 11s when tuned right.
You wont need to modify the postion of the twin CP3 it is nowhere near any of the plumbing for the twin kit.
There is also the II kit which is cheaper than MPIs, let the flaming begin.
Or you could make our own.
Durallymax is offline
post #4 of 26 (permalink) Old 05-24-2009, 10:18 AM
Its just a worktruck
DMAXchris's Avatar
The Industrial kit is only available for the LBZ/LMM currently. The MPI kit is top notch, almost looks factory. PPE is rumored to have twins in the works also.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #5 of 26 (permalink) Old 05-24-2009, 10:21 AM Thread Starter
Should I upgrade my factory turbo to one of PPE's and run that with MPI's?
post #6 of 26 (permalink) Old 05-24-2009, 10:28 AM
DMAXchris's Avatar
It's not required, but if you want more air, Go for it!! The PPE turbos are a bit pricey IMO. Look for a Borg warner S300. Durallymax can point ya in the right direction to have one spec'd for your truck and application.
06 LBZ EC/LB 4x4
post #7 of 26 (permalink) Old 05-24-2009, 11:03 AM
Banned
Wasnt there a thread about II same as MPI..???
post #8 of 26 (permalink) Old 05-24-2009, 11:26 AM
The03Dmax's Avatar
does anyone have a guesstimate on how much it would cost to twin turbo?
2003 LB7 CCSB Lifted 9x,xxx Miles,, 22x10.5 Novakanes ,Charcoal Matte Gray Vinyl wrap,Suncoast 1056, Gmax, SoFloDiesel 6" Custom stacks, PPE BIV, EFI Live Tuned by Rob, Merchant Motor Mounts, Eaton Tru Trac, Profab Horn, Airdog, Wetzel Wheel, Rare Parts T-rods, T-Case Brace, Pump Rub, Congnito Braces, 4" Custom welded intake,CTS Monitor,Autometer Boost/Pyro,Soflo Diesel Trac Bars, Totaled 1/16/15
2007.5 LMM CCSB 26x16 ,37" M/t's, 12" Cognito,Dual Fox Shocks/Resi,Soflo Diesel 8" Custom dss cats,Soflo Diesel Trac Bar ,AEM, EFI by Soflodiesel
1954 Dodge Job-rated with 12valve swap, 22's,5x16,s366,Suncoast,Dual Ram intake, fullcuts,4kgsk,60lb Vs,studded,Little Spray
The03Dmax is offline
post #9 of 26 (permalink) Old 05-24-2009, 11:30 AM
Banned
MPI's site has a great price section...
post #10 of 26 (permalink) Old 05-24-2009, 12:02 PM Thread Starter
MPI for my truck starts at $4500, I specifically bought a rolled over truck so I can afford all this.
