Old 06-26-2009, 12:15 PM   eBay Motors   #11 (permalink)
delong_1
truck for sale
delong_1's Avatar
when i ran ppe it did them same thing it didnt do it as bad on the lower levels but the upper levels was bad, im assuming too much fuel in c/c mode.
Nate
2 turbos, built trans, and some tuning.
Old 07-01-2009, 07:44 AM   eBay Motors   #12 (permalink)
k5blazerboy
k5blazerboy's Avatar
It still does it, its annoying enough where I might get rid of it. I need my C.C.
2001 Duramax 4" MBRP straight, PPE Standard, gauges, PPE boost valve. 285 BF all terrains on 16" American racing rims
1975 Chevy Blazer Custom Paint 8" lift, 37" Nitto Mud Grapplers 400 small block bored .40 over BLOWN UP (again) under 500 mi 4k gone! CAN ANYONE REBUILD A BOTTOM END?
06 Brute force 750, Galaxy Silver, 28" laws, snorks, radiator relocated, HMF swamp series exhaust, Dynatec CDI, will trade laws for some 27" Zillas
P.S., I voted for the other guy
k5blazerboy is offline   Reply With Quote
Old 07-01-2009, 12:03 PM   eBay Motors   #13 (permalink)
K9Duramax
K9Duramax's Avatar
Not knocking or doubting- but I can't believe that the PPE it is doing it. Set your truck back to stock for a couple of days (depends on how many miles you drive with it) and see what happens. Then, set your PPE to level 1, do a trans relearn, give a couple of days and see how it is- if good then move up to level 2 and do same.
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 07-01-2009, 09:18 PM   eBay Motors   #14 (permalink)
k5blazerboy
All im saying is the CC worked that day even with the edge at higher tunes with no problem. I guess I will try a lower tune once and see what happens.
Old 07-02-2009, 09:49 AM   eBay Motors   #15 (permalink)
K9Duramax
K9Duramax's Avatar
Dude, I'm not knocking- trying to help you figure out where the problem is, that is why I suggested the uninstall, drive it, then reprogram on level 1 to start and see what happens. If you still have the problem then I would call PPE- there is an issue if it happens after being taken out and put back in on level 1.... maybe they would have an answer, but then you know that you have done all you could do to aleviate yourself....
http://lb7.info/
Old 07-02-2009, 09:54 AM   eBay Motors   #16 (permalink)
chevytruckkid79
it will re learn. you just have to use the cruise control for a long time. it did it with my truck for about 2 weeks or so then cleared up.
01 GMC crew cab long bed. arp head studs. grade c head gaskets. new injectors and injection pump. banks 6 gun with pda. banks intake and wastegate valve. 4" exhaust with 6" stacks. ats built allision.(not to happy with it now)
chevytruckkid79 is offline   Reply With Quote
Old 07-02-2009, 09:56 AM   eBay Motors   #17 (permalink)
k5blazerboy
Not saying your knocking, just saying what I noticed, no worries, I will give it a couple more weeks and see what happens
Old 07-07-2009, 03:27 PM   eBay Motors   #18 (permalink)
racerx909
Mine surges when the engine is cold (maybe 5mi into a drive, tops). Goes away soon after.
03 2500 ECLB LT Pro Comp, 285's, PPE Hot, Resonator Mod
racerx909 is offline   Reply With Quote
