Old 06-30-2009, 01:17 PM   eBay Motors   #1 (permalink)
GMC FishHauler
Question Need Advise on Correcting Small Problems
Hey guys,
My truck shows "Check Engine" light. When I had the code read it said MAF Sensor Fail. I probably had my K&N over oiled and fouled the sensor. I attemped to clean with alcohol since that is what a shade tree mechanic told me to do, but still shows a fault even after getting reset. Is there an aftermarket part to replace the sensor or delete it? I dont mind a little smoke.
I am also looking for a EGR valve delete kit. Never messed with one of these things before so ANY advise on this will be appreciated. My truck has one for sure, I checked.
Last thing, I tore loose the two front wheel speed sensors when I removed the lift kit from my truck on accident. I rewired them but still throws a fault. I am replacing them with aftermarket parts for a lot less than I would pay at dealership. Does anyone know if this is a simple project? It looks pretty straight forward to me, I know I will have to get it reset after but that is no big deal.
Thanks in advance for ya'lls help.
2002 GMC 2500HD Crew Cab 4x4
68,000 miles
K&N Air Filter, 4" Silverline Exhaust w/ 5" tip
Tuning by Duramax Tuner
Speedliner on bumpers and bedrails
GMC FishHauler is offline   Reply With Quote
Old 06-30-2009, 01:30 PM   eBay Motors   #2 (permalink)
RedBowTies88
RedBowTies88's Avatar
the maf sensors are a little pricey. CRC makes a cleaner just for that though they should have it at your local chain auto parts store.
do you wanna take the whole egr system off or just use a blocker plate?
sorry i cant help on the wheel wheel speed sensor but someone will chime in
Cc/sb LLY 4x4, aerodynamic passenger door dent mod, 6-gun/SL and SC flashpaq, egr blocked, factory 3 1/2 straight piped, banks ram air, home made spring clamps, sleeves and braces, msd dual lazer gauge. Trutrac Diff. NEW BEST TIME... 14.140 at 94.69 still using 2WD
Very hurt tranny
RedBowTies88 is online now   Reply With Quote
Old 06-30-2009, 01:36 PM   eBay Motors   #3 (permalink)
GMC FishHauler
well, after reading several other posts on the EGR valve, I am not so sure that I do have one. There is something that looks like the EGR valves on gasoline engines, but I do not think that I have the vaccuum pump things. I am probably mistaken about the EGR, I will take another look at it.
I have done several google searches for the MAF, where do ya'll find them? I do not mind paying for one, but what does it really do? I just noticed my mileage DIE when that light came on.
68,000 miles
Old 06-30-2009, 01:45 PM   eBay Motors   #4 (permalink)
RedBowTies88
the maf is in the intake just behind the air filter if you have a stock intake.
i would say you having an egr is unlikely.
have you cleared the code? if you drive around with the check engine light on sometimes it will run differently causing the poor mileage.
get some of that CRC maf cleaner take out the maf (your gonna need a torex bit) and clean it with that stuff and see if it fixes the problem
Very hurt tranny
Old 06-30-2009, 01:46 PM   eBay Motors   #5 (permalink)
RedBowTies88
and also take out that k&n clean it and then oil with the proper amount of oil. OR put the stock filter in and see what happens.
ALSO make sure the connection to the maf is tight
Very hurt tranny
Old 06-30-2009, 01:49 PM   eBay Motors   #6 (permalink)
gr8shot
LMM'N
gr8shot's Avatar
the MAF measures how much air is entering the engine. This lets the comptuer know how much fuel to inject. If it gets dirty the readings aren't as accurate, hence bad mileage. You dont want to use anything but actual MAF sensor cleaner. Anything else can leave a residue on the sensor and it still won't read accuratley.
crawl under your truck and look at the exhaust. There will be a muffler towards the back, and there may or may not be a catalitic converter more towards the front. If there is a cat then there will also be an EGR valve in the engine compartment. The other way to check is to look at the codes in the glovebox. If you have the code "FE9" then you won't have a cat or EGR.
Oh, and DO NOT touch the little wires on the MAF sensor. the oil from your fingers can ruin it. Only hold it by the outside.
Jesse Meyers | Husker Diesel
EFI Live|PPE|MBRP|Quadzilla|Suncoast|Auto Meter|AirDog|Edge|+ many more
Specializing in custom EFI Live Tuning
www.huskerdiesel.com | Email us!
MBRP Summer Sale | Fuel Filter Sale
Shipping to Canada now available on ALL products!
07.5 CCSB LTZ
Old 06-30-2009, 02:03 PM   eBay Motors   #7 (permalink)
GMC FishHauler
OK, I def. did not have a cat converter. When I went to straight pipe all I had was the monsterous muffler, not cat.
I am pretty sure that the MAF is ruined, but I will try to clean it with the right stuff.
Thanks for all the timely replies. I am gonna email you Mr. Meyers, I have some questions about EFI.
68,000 miles
