turbo horn question - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 11-11-2013, 09:15 PM Thread Starter
dmax28's Avatar
turbo horn question
so im looking at getting a profab intake horn and been reading abut them on here but I see something about a wire loom mod.. can someone tell me what this is and how can I fit this turbo horn on
2003 lb7 cclb 4x4 leveled on h2 rims with 285-70-17 Cooper St maxx - 4 inch diamond eye turbo back with 6 inch tip - FTE resonator (zero cab drone) - S&B CAI with dry filter - Efi live with dsp5 switch - Ryans Diesel stage 2 trans and built transfer case - smoked cab lights and parking lights - autometer phantom 2 boost gauge - glowshift egt gauge
other ride- 1989 toyota pickup, 3.0 v6, 5 speed, 4 inch lift, 33s, never seen a winter
Originally Posted by willsdiesel View Post
I can't wait to get underneath It and start tearin shit offffff
dmax28 is offline
post #2 of 8 (permalink) Old 11-12-2013, 07:59 AM Thread Starter
dmax28's Avatar
bump
dmax28 is offline
post #3 of 8 (permalink) Old 11-12-2013, 03:02 PM Thread Starter
dmax28's Avatar
anybody?
dmax28 is offline
post #4 of 8 (permalink) Old 11-12-2013, 03:05 PM
franks71vw's Avatar
just push the wire for the intake heater a bit forward... Also to fit it you need to install 2 of the screw supplied onto the two lowest bolts on the turbo housing and then slide the horn from top to bottom. If you look at the horn you will see that the flange on the horn is cut out to do this slide in. Then once in you just insert the top bolt. Also you may or may not have a gasket, while doing mine, I had a gasket and it was torn form emoving the stock horn. used a razor to clean up and inserted a new gasket.
LB7 Dually 3500 CCLB with Lincoln Diesel Injectors, Ready Lift leveling keys, ProFabTurbo Horn, Bilstein 5100 Front Shocks, BD Performance Manifold, Banks 4" Exhaust, Banks Big Head Waste Gate, PPE boost valve, 235/75/16 stock wheels 1.5" spacers all around, Ghost Fuel pressure gauge 0-60psi, EGT, Boost, DSP5 Key Switch, Moonshine EFI tunes, High Idle MoD, Nictane Adapter with 1r0750 filter, ATP Sleeves, COGNITO Braces, Single 07+ driveshaft with yoke upgrade.
DF DRW CLUB MEMBER #177
My Build/Info Thread
http://www.duramaxforum.com/forum/01...b7-engine.html
franks71vw is offline
post #5 of 8 (permalink) Old 11-12-2013, 03:24 PM Thread Starter
dmax28's Avatar
so all u have to do is push the intake heater wire out of the way
dmax28 is offline
post #6 of 8 (permalink) Old 11-12-2013, 03:28 PM
franks71vw's Avatar
Yup, I would inspect you fuel hoses in the valley, since doing my injectors, I found two of them off the CP3 that were cracked and ready to leak. FYI
post #7 of 8 (permalink) Old 11-12-2013, 03:54 PM Thread Starter
dmax28's Avatar
thanks for the help bud
dmax28 is offline
post #8 of 8 (permalink) Old 11-12-2013, 04:46 PM
franks71vw's Avatar
No worries good luck...
