Old 08-23-2009, 09:40 PM   eBay Motors   #1 (permalink)
01DMAXX
injectors
I have an 02 lb7. It smokes at idle and then goes away when you start driving. I know its the injectors. But i dont know if i should go with a set of aftermarket 50hp injectors, or if i should just go with oem. Any suggestions would greatly be apprieciated. I plan on getting efi live and getting pretty crazy. But for now keepin it kinda mild.
01DMAXX is offline   Reply With Quote
Old 08-23-2009, 09:42 PM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
filll out your sig.
what mods do you have.
Old 08-23-2009, 09:44 PM   eBay Motors   #3 (permalink)
TMX864
TMX864's Avatar
bump..wondering the same thing. mine are fine for now but just wondering what to do if and when they go
2004 LB7 ECSB Named TONKA
Quadzilla S2, CAI, 4in turbo-back to 7in single black stack, Resonator blocked
Bullydog Outlook monitor
Pro Comp 20's 305x55 Nitto Terra Grapplers
T-Bars Cranked
2 Kicker CVR 10s
For all you Wheel and Tire needs shop http://www.discounttiredirect.com
TMX864 is offline   Reply With Quote
Old 08-23-2009, 09:50 PM   eBay Motors   #4 (permalink)
01DMAXX
aem brute force intake, diablo predator, 5 inch straight pipe and ppe boost valve. Im new to the diesel. Whats exactly is sig
Old 08-23-2009, 09:52 PM   eBay Motors   #5 (permalink)
jesselb7
jesselb7's Avatar
your signature, basically what truck you have and what mods you got too.
- Jesse
02 Chevy CC SB 4x4 LB7
T-Bars Cranked on 305 Nitto Terra Grapplers
bone stock...for now.
www.huskerdiesel.com
jesselb7 is offline   Reply With Quote
Old 08-23-2009, 09:55 PM   eBay Motors   #6 (permalink)
ChevyDMax89
ChevyDMax89's Avatar
Stock injectors are good for up to about 600 hp, but do the 50hp or even 100hp aftermarkets if you want. It won't hurt. It will definately dump black smoke alot more
2001 CC/SB Duramax Diesel LT 4x4 LB7, Solid axle conversion, 12" lift, 16.5" Eagle Alloys, 40x18x16.5 Mickey Thompson Baja Belted Tires, PPE Hot+2, Van Aaken performance smart box E, MBRP 4" Turboback Straight Pipe w/5" Tip, (4) 10" Subs with Audiobahn amp.
LIFE'S TOO SHORT, PARTY NAKED!!!
ChevyDMax89 is offline   Reply With Quote
