Old 12-24-2007, 06:12 PM   eBay Motors   #1 (permalink)
antlers70
2002 Duramax No Power P0101 Code
I just bought a 2002 Duramax, it came with a K&N intake system on it and 4" straight pipe exhaust. I put a Hypertech programmer on it and keeps giving me the P0101 code and the truck has absolutely no power. I cleaned the MAF sensor and it ran awesome for about 2 weeks and then no power again. I tried cleaning it again and still no power. I'm getting really frustrated with this truck. I know it should have way more power that its giving me. Please Help!!!!!!!
antlers70 is offline   Reply With Quote
Old 12-24-2007, 06:25 PM   eBay Motors   #2 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
Oiled filters and MAf sensons dont get along very well, the problem usually comes from over oiling the filter and then the oil gets sucked out of the filter and ends up on the MAF sensor causing codes. Try cleaning it again and be careful how u clean it they are some what fragile!
Mine- 05 RC/LB D/ZF-6-Twin turbos, twin pumps, Tripple clutch
Hers-04.5 CC/SB D/A Big turbo, Big pump, Big trans
runNADM.com
EFI Live By whoever my tuner "barrowed" his tunes from!
Old 12-24-2007, 06:57 PM   eBay Motors   #3 (permalink)
antlers70
How do you recommend cleaning it. I was told to spray it off with Carb cleaner. Also how do you know if the sensor needs to be replaced? Thanks
Old 12-25-2007, 02:39 AM   eBay Motors   #4 (permalink)
whitebull
I also have a 2002 Duramax and had the same problem. It turned out that I had to replace the fuel filter. When I replaced it I got all power back and could really feel the difference when the turbo kicked in. Since then; just as most other people say; I change the fuel filter every 10;000 and have had no problems since.
PS: I am also running a 4 inch exaust with a power intake.
whitebull is offline   Reply With Quote
Old 12-25-2007, 11:06 AM   eBay Motors   #5 (permalink)
antlers70
I replaced the fuel filter about 2,000 miles ago and it didn't help. Whatever is going on it is a night and day difference in power and it is intermittent. Does anyone know how drastic of a power reduction you will have with a MAF sensor that is not working right? I do think something is going on with the fuel because I can turn the chip up all the way and still not get any smoke.
Old 12-25-2007, 05:46 PM   eBay Motors   #6 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
100% of the engine fueling can be controled by the MAF especially if its showin no air flow!
If cleaning it dose not help it probally needs replaced, but hold on to your wallet they arent cheap for all the bigger they are. But i would try cleaning it again, inspect it good make sure there is nothing stuck up in it or around the elements in there. I would use electrical contact cleaner, u can usually pick it up in a computer store or a radio shack type store!
runNADM.com
Old 12-25-2007, 08:13 PM   eBay Motors   #7 (permalink)
antlers70
Cool, thanks I'll try it. Also does anyone know where I can get the same cone style filter as the K&N. I dont want to run an oiled filter if I'm going to keep having this problem.
Old 12-25-2007, 08:45 PM   eBay Motors   #8 (permalink)
duramaxin14
duramaxin14's Avatar
Autozone sales them
Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
duramaxin14 is offline   Reply With Quote
Old 12-25-2007, 11:12 PM   eBay Motors   #9 (permalink)
dmax500
dmax500's Avatar
cant remember where i saw it but donaldson is making clamp on power core filters for intake systems now could be your answer if you can find them.
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. PPE pyro and boost gauges havnt installed yet. air dog 150 lift pump in future installed a fass 150/150 and was impressed with results
dmax500 is offline   Reply With Quote
Old 12-25-2007, 11:17 PM   eBay Motors   #10 (permalink)
dmax500
dmax500's Avatar
found it.
Volant Performance PowerCore Universal Filter - VP615
