Old 10-11-2009, 06:44 PM   eBay Motors   #11 (permalink)
custom8726
custom8726's Avatar
Check to see if you have any wires spliced into the purple wire under the dash at the OB2 connector. I had a similar issue once.
[b]05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, PPE HOT+2 ET -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, LBZ mouth piece, COGNITO H.D. TIE RODS & BRACES.
EFI LIVE, DSP-5...... ATP TUNING, 40 over BD Injectors 4" T.C. lift, 35" Nitto graplers, Rancho 9000's
custom8726 is online now   Reply With Quote
Old 10-11-2009, 10:23 PM   eBay Motors   #12 (permalink)
illinoischris
Thanks for the replies so far. The unit of course has power, and can communicate with the truck, I can do the diagnostics and see fuel pressure, throttle pos, etc. It just the PCM unlocking that doesn't work. One more thing it does is immediately after pressing "Y" to tune, and it shows the "Unlocking PCM", the dash including gauges, info center and dummy lights "reset" similar to shutting the key off and on again. This lets me know the unit is "talking", but alas, the error occurs.
From the replies it sounds like two votes for EFI Live. I hate the thought of buying another programmer, after two purchased with zero results, I need to sleep on that one.
illinoischris is offline   Reply With Quote
Old 10-11-2009, 11:02 PM   eBay Motors   #13 (permalink)
C-Power
C-Power's Avatar
well if you decide to get efi.... you can throw your PPE this way
FOR SALE
~01' GMC LB7 ~2500 Crew Cab~K&N Intake~4in turbo back ~5in miters~Quadzilla Stealth 2 ~3in leveling kit~american racing rims~305's
C-Power is offline   Reply With Quote
Old 11-01-2009, 09:53 PM   eBay Motors   #14 (permalink)
smav
Same problem with bullydog
I have a 2003 duramax and was attempting to get a bullydog to down load and it gives me the same problem. During the unlocking PCM stage it comes up with an error stating it cannot communicate with PCM. The gauges work and I can get the codes if something fails, the VIN comes up correctly but it will not do the down load. I tried it on a ford and it worked like clock work. I also have tried it by leaving in the fuses, pulling the ones it states and also pulling any other fuse that wouldn't be related to the PCM. Same error everytime. I checked the 2 grounds, signal and power wire on the DLC and all are good. It also resets all the guages as you posted once it comes up with the error that it cannot communicate with the vehicle.
smav is offline   Reply With Quote
Old 11-06-2009, 08:16 AM   eBay Motors   #15 (permalink)
illinoischris
I hear you. Mine is the same way, everything on the truck is working and i can read diagnostics, reset the trans, but not download. I have tried about every combination of fuse pulling possible, had the dealer flash the pcm, etc, still not working. I have basically given up for now, i have not gotten any good ideas from anyone.
Old 11-06-2009, 08:24 AM   eBay Motors   #16 (permalink)
mijdirtyjeep
mijdirtyjeep's Avatar
You could call the person you bought it from and see if you can return it. The Vender I bought mine "Quad Stealth2" on from here even sent a pre-paid box VIA UPS. I do not know how long you have had it or if you even bought it new, but if new and it has been just a short period of time it might be worth asking.
Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2
mijdirtyjeep is offline   Reply With Quote
Old 11-06-2009, 09:31 AM   eBay Motors   #17 (permalink)
C-Power
C-Power's Avatar
haha yeah just dont sent it to quadzilla.........cheap bastards.......the first one i had to send back to schied......i had to pay shipping b/c they sold me junk.....second time to quadzilla same thing i had to pay for it to be shipped all the way to texas b/c thier junk product.......its BS......
FOR SALE
Old 11-10-2009, 02:58 AM   eBay Motors   #18 (permalink)
KingV
I was having this problem with my 03. I had a Power Pup and tried a ATS EPower and neither would load so I figured it was time for EFILive. When I got EFI I tried reading the ECM and it would get a bootloader error so I posted on their forum and found out my ECM was corrupted by the dealer. I installed another ECM and now it works like a charm. I read that GM's TIS programmer will corrupt the ECM when things go wrong during a TIS reflash.
KingV is offline   Reply With Quote
Old 11-10-2009, 05:35 AM   eBay Motors   #19 (permalink)
lubeman1969
lubeman1969's Avatar
Is it possible your current files are "locked" by some sort of programmer now and has to bew set back to stock before any other can be used? You may have already addressed this and I missed it.
2006 2500 LBZ CREW CAB LONG BED * NFAB STEP BARS
35" TOYO OC MT"S W/ 18" ROCKSTARS * FABTECH 6" LIFT * FABTECH HD TIE RODS
BD FULL BORE MANIFOLD * S&B CAI
4" STRAIGHT PIPE EXHAUST * MBRP 5" TIP
TRANSGO JR 4/11/09...THIS WAS A GREAT MOD!!!
BANKS INTERCOOLER * RESONATOR HOLE PLUGGED
EGR BLOCKER PLATE * EDGE INSIGHT MONITOR
TUNED WITH EFI LIVE>>>NOTICE I AM SMILING!!!!
www.huskerdiesel.com
lubeman1969 is offline   Reply With Quote
Old 11-10-2009, 10:35 AM   eBay Motors   #20 (permalink)
smav
I was thinking along the same lines as Lubeman, that the program may be locked out. It also could be corrupt as well. I have experianced a Ford dealership doing that to some of our work trucks where they went to flash it and they ended up haveing to order and install a new PCM or ECM because they couldn't write to it. I am kind of a miser and a little hesitant to take it to the local chevy dealer as I don't want to spend the money to have them update or flash the PCM just to find out it still doesn't work. It would be different if a guy knew exactly what they were looking for, (I.E. is it locked or corrupt).
