Old 10-25-2009, 05:47 PM   eBay Motors   #1 (permalink)
duroforshuro
PPE Standard
just installed my ppe standard on level two and im realy impressed! Got a couple questions though.
1. what is defueling and should i have it off or on
2. what is timing added and should i have that on or off
3. and what about transmission relearn and should i do that
2004 Duro
PPE Standard programmer
K&N drop in filter
Stock straight pipe
duroforshuro is offline   Reply With Quote
Old 10-25-2009, 06:05 PM   eBay Motors   #2 (permalink)
GOGODURAMAX
GOGODURAMAX's Avatar
Defuel needs to be on.(It will help your tranny last longer).
Go to beginning when you first hook it up and go to trans reset.
GOGODURAMAX is offline   Reply With Quote
Old 10-25-2009, 06:27 PM   eBay Motors   #3 (permalink)
duroforshuro
what is the timing added option.
2004 Duro
K&N drop in filter
Stock straight pipe
Old 10-25-2009, 07:36 PM   eBay Motors   #4 (permalink)
DuraTitus
DuraTitus's Avatar
It injects the fuel sooner in the cylinder cycle so the explosion is sooner which is harder on the engine because of increased pressure. I would have it on because you are looking for more power, which automatically will decrease your engine life.
You may still get 350,000 miles out of your engine, and if you are concerned about engine life leave it on stock settings!
I have the increased timing option on in my truck!
Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
DuraTitus is offline   Reply With Quote
Old 10-26-2009, 10:01 AM   eBay Motors   #5 (permalink)
duroforshuro
thanks! also if i want to fun it on level 3 what do i need to do? a transgo jr kit or what? and say i want to run it on level 5 i know i need a tranny rebuild but is there anything else i would need?
2004 Duro
K&N drop in filter
Stock straight pipe
Old 10-26-2009, 10:08 AM   eBay Motors   #6 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
the trango jr does nothing for the 5 speed allison. the allison will learn to shift back to normal. The only real way to make your tranny last is to do a full build on the tranny.
Old 10-26-2009, 10:12 AM   eBay Motors   #7 (permalink)
jc1843
You can damage the tranny on "3" and even lower setting if you are an aggressive driver. The only thing you can do is be light footed, when shifting 4 to 5 and 5 to 4.
The TransGo Jr can help a little on the 5 speed by improving the shifting. It does help the 6 speed more because they have better clutches.
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 10-26-2009, 10:15 AM   eBay Motors   #8 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
I dont think that is the case..i think they use the same clutches. the reason the transgo jr works better on the 6 speeds is because they already have the upgrades that come in the full trango kit for the 5 speeds.
Old 10-26-2009, 10:18 AM   eBay Motors   #9 (permalink)
duroforshuro
so if im gonna do anything to my tranny i should just go for a stage 4 and quite pussy footing around
2004 Duro
K&N drop in filter
Stock straight pipe
Old 10-26-2009, 10:20 AM   eBay Motors   #10 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
yep...or a suncoast III if the right person builds it.
