Old 10-30-2009, 10:44 AM   eBay Motors   #1 (permalink)
45Colt45
45Colt45's Avatar
Down to the Nitty Gritty concerning the Allison Transmission
As I read through all of these posts I see a common trend, only 90 additional rwHP on stock tranny, don't waste your time on Transgo shift kit (have to take the entire tranny out anyways 01'-03'), and most importantly "TRANSMISSION FIRST" if you are planning on some real horse power/torque.
After reading and reading I have come to the conclusion that the tranny is the weak point, but it is confusing because I looked for six months before I bought my 02 and I found many trucks with all kinds of power adders coupled to stock trannys. With that being said here are a few questions for those of you with more experience than I.
- What is the advantage of running full sythetic in tranny/diffs/transfer case?
- How often should an individual change fluid in tranny: economy driving vs. extreme racing/towing?
- Is there an advantage to a deep sump finned tranny pan or finned diff pan?
- If you have a mild build 100-200 additional HP can you get away with only a torque converter upgrade?
- At what point in your upgrades is the tranny neccessary? (clarification) if you are adding power for economy "long flat driving" do you really need this upgrade as soon as more extreme situations "quarter mile racing, towing, or playing in the dirt"?
- If you have a basically stock truck or maybe just 50-75 additional HP, but you drive the heck out of it, or tow a considerable amount of weight, should you consider a tranny upgrade?
-Lastly, how do you decide what level of transmission upgrade you need?
Thanks everyone for the info, just a little confused on this end, I see trucks all the time with 120HP tunes, intakes, and exhausts on stock trans and they seem to drive fine, but I figured its all about the way you drive it, or how often you service it????
2002 Chevy crew cab short box LT package and Auto Trans. Truck is completely stock, but looking to change that soon!
2002 Chevy Camaro SS "35th anniversary edition"
2005 Chevy Avalanche
1988 20' Weldcraft Jetboat
1965 Malibu SS
45Colt45 is offline   Reply With Quote
Old 10-30-2009, 11:04 AM   eBay Motors   #2 (permalink)
scottdomine
scottdomine's Avatar
I'm sure that driving habits have a lot to do w/ how long your stock trans will last. The Allison trans is fantastic when kept to it's original specs, but if you're adding power and aren't afraid to use it, then it's not gonna last. I run a PPE on level 2 and sometimes 3. I have a little fun at lights and such and tow an enclosed trailer w/ my stock car in it (about 8,000 lbs) up the mountains here in AZ (on level 1 only when towing) and have never had any problems at all. I've been running this setup for 3-4 mos and everything seems just fine, but most of my driving is "normal" light-footed stuff. It's only once in a while that I feel the need for putting it to the floor. Many go by the moto, "you have to pay to play" and I couldn't agree more.
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 10-30-2009, 11:09 AM   eBay Motors   #3 (permalink)
Dirtbikindad393
Your #1 Source For Amsoil
Dirtbikindad393's Avatar
Short Answer; Synthetics have less friction and can withstand higher heat before breaking down. They also handle severe cold temps much better.
- How often should an individual change fluid in tranny: economy driving vs. extreme racing/towing? That depends on the fluid and how much extreme driving is done. If your using Synthetics I would change it every 50k for the extreme driving part. If using conventional every 25k.
- Is there an advantage to a deep sump finned tranny pan or finned diff pan? The advantage to both is that you increase the fluid capacity by 3.5 qts in both the trans and rear diff. More fluid means better able to handle and disperse heat and will help extend fluid change intervals.
- If you have a mild build 100-200 additional HP can you get away with only a torque converter upgrade? You can do it but will it keep your trans from slipping probably not. The TC is the weak link after that the clutches in the trans are the weak link.
- At what point in your upgrades is the tranny neccessary? (clarification) if you are adding power for economy "long flat driving" do you really need this upgrade as soon as more extreme situations "quarter mile racing, towing, or playing in the dirt"? At the point you go over approx 90 HP added to stock.
- If you have a basically stock truck or maybe just 50-75 additional HP, but you drive the heck out of it, or tow a considerable amount of weight, should you consider a tranny upgrade? Most likely yes. The weight and towing will eventually get to your trans as well as the driving the heck out of it. It will take longer to slip but once it does its done.
-Lastly, how do you decide what level of transmission upgrade you need? By how much power you want to add and need the trans to hold unless money is no object then just got for it all the first time.
See answers in red above.
Yes its the way you drive it! Most people get the power and can't drive the same way as when they didn't have power.
Hope that helps some.
MadJack Racing & Synthetics
MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
Dirtbikindad393 is offline   Reply With Quote
Old 10-30-2009, 11:33 AM   eBay Motors   #4 (permalink)
floridamax
floridamax's Avatar
Great, Greeat questions man. Thanks
08 GMC Crew cab long bed 4x4 with 20'' xd spy and terra grappler 305/55/20. airaid filter and box. I just changed hypertech max energy set on stage 1 for better fuel economy to the quadzilla stealth 2 set on on economy and the difference is awesome. better driving, shifting and fuel economy.
P.S.
My fife didn't want me to buy the truck and buy all the upgrades for it so I decided to get rid of the wife!!!!!!
floridamax is offline   Reply With Quote
Old 10-30-2009, 11:37 AM   eBay Motors   #5 (permalink)
Meyerperformance
Looking for low 12's.
Meyerperformance's Avatar
For what trans you want, it depends how far you want to take your truck. For the most part a Stage III will handle anything the stock engine will handle.
MPF
812.344.4421
We Price Match!
Old 10-31-2009, 04:15 PM   eBay Motors   #6 (permalink)
Rickytree
I agree I like your sig. Not a bad deal Lose the wife. Get the truck of your LIFE. Just got my truck and can't wait to treat it out for a sweet upgrade. I think I might be in LOVE!
Rickytree is offline   Reply With Quote
Old 10-31-2009, 04:24 PM   eBay Motors   #7 (permalink)
Specialized89
Specialized89's Avatar
So if you are supposed to upgrade your transmission after an additional 90HP, does that mean you should be upgrading it if you are running lets say a 90HP tune and an intake, exhaust(no cat or muffler) and other small modifications like a boost valve and some other small power adders? Because that equates to a bit over an additionl 90HP.
2004.5 Chevrolet Crew Cab Short Box.
6.6 LLY/Allison 1000 5 speed.
4'' of lift w/ Yokohama Geolanders.
aFe intake (stage 1)
Unknown brand 4" exhaust.
aFe Mouth Piece.
Specialized89 is offline   Reply With Quote
Old 11-03-2009, 09:23 AM   eBay Motors   #8 (permalink)
45Colt45
45Colt45's Avatar
It is pretty confusing I agree Specialized 89, I have a neighbor who has an 06 with intake, exhaust, and a 225 HP tune on a stock tranny, and he claims that he has run that since 2007 without any difficulties and he occassionally pulls a 30ft travel trailer. It looks like he only uses the truck about twice a week so maybe he has put 20,000 miles on the entire package but it seems hard to believe that only an additional 100 HP will kill your tranny.
Even as it is hard to believe though, I am personally going to err on the side of caution:
90HP Tune, intake, turbo horn mod, exhaust, engine brake, on a stock tranny. After I save up I will upgrade the tranny and then keep going with it from there.
1965 Malibu SS
Old 11-03-2009, 10:01 AM   eBay Motors   #9 (permalink)
IdahoRob
IdahoRob's Avatar
Remember tuners claims on HP are all different. Some at the crank, some at the wheels, but most over rated.
Give me a call and I'll talk through your questions. Over the years, I've tried almost every form of tranny upgrade in steps and know what power levels these upgrades fail at.
2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 11-04-2009, 04:44 PM   eBay Motors   #10 (permalink)
45Colt45
45Colt45's Avatar
Pretty interesting information I recieved today!
I called a regional dealer and got connected with the service side of Allison Transmissions, the headquaters back in like indianna or something. Gave them the model number and the series of transmission I have and asked them some basic information about transmission limits. I am positive that these are conservative but something to think about.
Allison Rates the 1000 series transmission to handle 340HP and 550Ft Lbs of torque.
Looking the specs up on my truck tells me that my 2002 LB7 came with 300HP and 520Ft Lbs of torque from the factory. So by there specifications I can safely add 40HP, and 20 Ft Lbs of torque.
I realize that many of you have been doing this for WAY longer than I and know what the true limits of the transmission are but this is certainly interesting.
1965 Malibu SS
