Old 10-30-2009, 08:59 PM   eBay Motors   #11 (permalink)
chevy71pickupman
chevy71pickupman's Avatar
don't do that. there is a special cleaner for the sensors and that is what you should use. It is a MAF sensor cleaner. And is it the MAP sensor or your MAF sensor? Just checking is all. Normally it will only mess up the MAF sensor on the intake tube. I would think it would take a lot of extra oil to mess with the MAP sensor.
PICKUP: 01 2500HD CHEVY SILVERADO REGULAR CAB LONG BOX WITH HELPER AIR BAGS AND GOOSENECK
TURBO: STOCK WITH PPE BOOST VALVE AND MODIFIED INTAKE HORN
TRANSMISSION: STOCK ALLISON 5 SPEED
INTAKE: BANKS COLD AIR INTAKE NO SCOOP
Truck 2: 1971 Chevy K20
Engine: Built 350 about 350 to 370 horse estimating.
chevy71pickupman is offline   Reply With Quote
Old 10-30-2009, 09:06 PM   eBay Motors   #12 (permalink)
trevorb_06
trevorb_06's Avatar
P0107 code reads MAP (Man. absolute pressure)/ BARO or MAF (Mass Air Flow) / VAF (Vane Air Flow) Sensor condition explanation
All vehicles have one or more of these components. Engin load or the AIR volume entering is measured by these components. The computer has recognized a return signal error.
Probable cause
1. Vacuum hose off, cracked, or passage blocked - Engine mechanical timing condition
2. Throttle body intake tube loose, off, or cracked
3. BARO (Barometer)/MAP (Man. Absolute Pressure) defective
4.VAF (Vane Air Flow) MAF (Mass Air Flow) Sensor dirty or defective.
Truck: 02 LB7 Chevy 2500HD 4x4 Crew Cab Long Box LT
Add-ons: Reflexxion Ram Air Style Cowl Induction Hood, 285/75/16 Wildcat EXT, Spray on Bed Liner, Firestone Rear Airbags
Performance: Banks Ram Air Intake, 3.5" Straight Pipe, PPE Boost Increase Valve, Turbo Intake Horn Mod
Wish list: Too long to list!!!
Let The Coal Roll
trevorb_06 is offline   Reply With Quote
Old 10-30-2009, 09:09 PM   eBay Motors   #13 (permalink)
foxracingfreak
Im gonna say that number 4 is your problem. If you take off your MAF sensor and clean it I am sure you will find it is dirty.
foxracingfreak is offline   Reply With Quote
Old 10-30-2009, 09:10 PM   eBay Motors   #14 (permalink)
trevorb_06
trevorb_06's Avatar
Yeah that is what I figured, but just didnt know what to clean it with
Let The Coal Roll
Old 10-30-2009, 09:14 PM   eBay Motors   #15 (permalink)
foxracingfreak
chevy71pickupman is right the correct stuff to use would be cleaner that is safe for sensors especially for MAF sensors. Be real careful with the sensor they are not cheap to replace.
Old 10-30-2009, 09:54 PM   eBay Motors   #16 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
wonder why they call it a cold air intake....nothing is cold or cool about it in the first place...
