Old 10-30-2009, 08:31 PM   eBay Motors   #1 (permalink)
trevorb_06
trevorb_06's Avatar
Banks Ram-Air intake
Right off of the Banks web site....
Filter on a stick: a joke that’s not funny.
A filter on a stick is a bad joke. It’s wide-open to hot underhood engine air, and there’s no power in hot air! Ram-Air houses a giant lifetime filter in an enclosed cold-air box, which inhales cool, dense outside air—more than Banks’ competitors and up to 57% more than stock—for more power and mileage, lower EGTs and less smoke. And it's designed to not cause fault or error codes.
Ever since I have installed this my truck has thrown a P0107 code MAP sensor code. Anyone else out there with the Banks installed having this problem?
Truck: 02 LB7 Chevy 2500HD 4x4 Crew Cab Long Box LT
Add-ons: Reflexxion Ram Air Style Cowl Induction Hood, 285/75/16 Wildcat EXT, Spray on Bed Liner, Firestone Rear Airbags
Performance: Banks Ram Air Intake, 3.5" Straight Pipe, PPE Boost Increase Valve, Turbo Intake Horn Mod
Wish list: Too long to list!!!
Let The Coal Roll
trevorb_06 is offline   Reply With Quote
Old 10-30-2009, 08:41 PM   eBay Motors   #2 (permalink)
Crusher
Crusher's Avatar
I have no problems with my Banks CAI. Works as advertised.
2006 Chevy 2500HD LT CCSB 4X4 Duramax LBZ;
EFILive V2 Tuned by IdahoRob,
BANKS Ram Air Intake + Super Scoop,
BD Exhaust Manifold, EGR Blocker, 4" Turbo-back S/S Exhaust w/ Aero-Turbine 4040,
Transgo Jr., B&M Racing Deep Pan, Pure-Power Filter, SunCoast Deep Filter Lock,
Autometer Ultra-Lite II - EGT & Boost in overhead.
NCT/Bilstein Shocks, Firestone Ride-Rite Airbags, Open Country M/T, LINE-X, TruXedo Tonneau, Pro-Tech Toolbox,
Pioneer FH-P8000BT, i-pod, Focal 165KF Frt & Rear, JL Audio 300/4 Amp, Focal 27KX Subs, Audison Amp, Rattle-Trap Xtreme.
Crusher is offline   Reply With Quote
Old 10-30-2009, 08:42 PM   eBay Motors   #3 (permalink)
foxracingfreak
The filter is not an oiled type is it? I know with my K&N FPIK kit on my 5.3 gas it would pull a code because the mass air flow sensor got covered in oil. I had to take it off and clean off the sensor every once in a while.
foxracingfreak is offline   Reply With Quote
Old 10-30-2009, 08:43 PM   eBay Motors   #4 (permalink)
blott22
blott22's Avatar
mine works well. never have thrown a code
Brent
2006 Chevy LBZ Crew Cab W/T
PPE Standard
Resonator Plug, Transgo Jr.
Banks Ram Air Intake, Glowshift Gauges, Diamond Eye 4" Turbo Back, Limo Tint, 18" Moto Metal 955, Dual Flip Deck, 1200 watt amp, 2 Eclipse 10" subs.
FOR SALE
Diablosport Predator
blott22 is offline   Reply With Quote
Old 10-30-2009, 08:45 PM   eBay Motors   #5 (permalink)
trevorb_06
trevorb_06's Avatar
I think it is an oiled type but I have not oiled it, I had a body shop do the install since it was there already for a lot of body work. Not sure if they oiled it too much or not. But it has been quite awhile since install and it still keeps coming up after I clear it
Let The Coal Roll
Old 10-30-2009, 08:49 PM   eBay Motors   #6 (permalink)
blott22
blott22's Avatar
what kind of tuner u have?
Brent
PPE Standard
FOR SALE
Old 10-30-2009, 08:50 PM   eBay Motors   #7 (permalink)
trevorb_06
trevorb_06's Avatar
No tuner. All mods are in signature
Let The Coal Roll
Old 10-30-2009, 08:52 PM   eBay Motors   #8 (permalink)
chevy71pickupman
chevy71pickupman's Avatar
It comes oiled if they oiled it again it had to much on it and it sprays into the intake tube and will mess up your sensor. clean the sensor and see if it still does it.
PICKUP: 01 2500HD CHEVY SILVERADO REGULAR CAB LONG BOX WITH HELPER AIR BAGS AND GOOSENECK
TURBO: STOCK WITH PPE BOOST VALVE AND MODIFIED INTAKE HORN
TRANSMISSION: STOCK ALLISON 5 SPEED
INTAKE: BANKS COLD AIR INTAKE NO SCOOP
Truck 2: 1971 Chevy K20
Engine: Built 350 about 350 to 370 horse estimating.
chevy71pickupman is offline   Reply With Quote
Old 10-30-2009, 08:53 PM   eBay Motors   #9 (permalink)
trevorb_06
trevorb_06's Avatar
What should I use to clean it?
Let The Coal Roll
Old 10-30-2009, 08:54 PM   eBay Motors   #10 (permalink)
foxracingfreak
I just used parts cleaner... Not sure if that is the right thing to use but it worked on mine. I would maybe even pull the filter out and clean it off with filter cleaner and re-oil it but use just a little oil dont get to crazy with the oil.
