Old 10-31-2009, 06:29 PM   eBay Motors   #1 (permalink)
slimwolf
Slimwolf
slimwolf's Avatar
2"-3"
Anyone running a 2-3" lift on their truck? Are they a waste of time and money or are they good. I don't want a big lift on my truck, but do want a small lift on it. TIA
Brad
2003 K&N high airflow, edge, straight pipe, 285/75R16
1968 Thunder-Bird
1981 Camaro
slimwolf is offline   Reply With Quote
Old 11-01-2009, 01:51 AM   eBay Motors   #2 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
I personally put on the cognito UCAs, cranked my torsions and put rear lift blocks on. It was a good investment. You dont always have to change your torsion keys out. Most of the time you can get the lift you need with the stock ones. Here are a couple of pics of my truck:
Before
After
Old 11-01-2009, 05:39 AM   eBay Motors   #3 (permalink)
Pee Wee
If it were me, I'd do the cogito 4" front lift with 2" blocks in the back. The reason I like the cognito 4" is that when you are done you cv angles are correct (less wear).
My two cents,
PW
Pee Wee is offline   Reply With Quote
Old 11-01-2009, 06:07 AM   eBay Motors   #4 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
true, I would have done that, but i needed upper balljoints (UCAs dont come with the kit) so i went with the UCAs. My angles arent bad. Most lifts are that way though...just use lift blocks on the rear.
