Bully Dog shift kit - Chevy and GMC Duramax Diesel Forum
Old 01-17-2008, 03:13 PM   eBay Motors  #1 (permalink)
Extreme lb7 Dmax's Avatar
Bully Dog shift kit
How would the Bully Dog Shift Kit help my stock Allison transmission to hold up ?
2003 Duramax lb7
stock/5spd Allison
PPE standard
Silverline Exhaust
4 inch turboback
AFE air filter modded air box
Turbo Mouth piece mod
Extreme lb7 Dmax is offline   Reply With Quote
Old 01-17-2008, 06:14 PM   eBay Motors  #2 (permalink)
PVNISHER's Avatar
I put the kit in my truck and I love it, the first couple days it felt like I was driving a new truck again. Only problem was the Tranny Fluid to put back in it cost as much as the kit.
o6 CC,LB
ANCIENT SECRETS
The object of war is not to die for your country but to make the other bastard die for his.
--George Patton--
PVNISHER is offline   Reply With Quote
Old 01-18-2008, 11:29 AM   eBay Motors  #3 (permalink)
Administrator
ob_1jr's Avatar
Go with the transgo kit. I have heard of problems with the bullydog kit. That is just personal preference though. They are about the same price anyway. If you are just at stock power levels it is good. It might help you hold a little extra power too. I don't know the real world numbers since I haven't done anything to my tranny yet. I am just going to save up for the full upgrade so I can go a little crazy with power.
SOLD
305/70-16 BFG T/A KOs on Eagle Alloys Series 187
Clifford remote start. High Idle, Bilstein 5100s, 1.5" lift blocks
CAT fuel filter w/ nicktane adapter
Magnum Force Stage 2 intake with AMSOIL filter
Racor 2 Micron pre-OEM with heater & water sep
Lightforce 140s from Madjackracing
http://WWW.ATPTRUCKS.COM/
Old 01-18-2008, 06:56 PM   eBay Motors  #4 (permalink)
Bully Dog Kit..... Is TRANSGO.
If your afraid of the BD Kit don't use the same parts in a different box.
JacktheBear3 is offline   Reply With Quote
Old 01-19-2008, 12:23 AM   eBay Motors  #5 (permalink)
Administrator
ob_1jr's Avatar
The transgo is a little more complete than the bullydog. Here's what comes with the transgo: Transgo® Allison Shift Kit
and here is what comes the the bullydog: Bully Dog Site | Bully Dog Product
I may not be real smart, but the transgo kit comes with a lot more stuff than that bullydog kit. Do your research before trying to call me out. They are not the same kit. It also depends on the kit you buy for...the 6 speed one yes, they may be the same, but the 5 speed is not the same. The original question was about a truck with a 5 speed in it. I was basing my information off of that.
SOLD
Old 01-19-2008, 09:28 AM   eBay Motors  #6 (permalink)
I am with Ob_1jr on this one. Go for the trans go. We have installed several of them with great success! The trucks really respond well to them and it will help your trans hold up better to abuse. How much power are you planning to run through the trans? I only ask cause if you are going to try and run something like a PPE Hot +2, you will need more than the shift kit to use the PPE to its full capability!
Diesel Nut is offline   Reply With Quote
Old 01-19-2008, 09:35 AM   eBay Motors  #7 (permalink)
I guess that was my point.... if you have heard anything negative about the shift kit (either brand), it was because someone thought $200.00 was going to make the tranny hold 700RWP HP.
Old 01-19-2008, 11:55 AM   eBay Motors  #8 (permalink)
I Plan on running around 450 horsepower altogether.
Thanks, For the replys
2003 Duramax lb7
stock/5spd Allison
PPE standard
Silverline Exhaust
4 inch turboback
Old 01-19-2008, 03:09 PM   eBay Motors  #9 (permalink)
duramaxsandwich's Avatar
you're going to need a torque converter and a full transgo kit minimum. i would look at a suncoast stage III kit or an ATS equivalent.
the bullydog shift kit is worthless imo. your tcm will learn out of it and the trans will go back to the way it was before the kit.
2001 GMC EC/LB black D/A
2.8 puller
Built Motor, A5K, twin Cp3, big injectors, 6'' stack.....u get the idea...
NO LIMIT DIESEL PERFORMANCE
duramaxsandwich is offline   Reply With Quote
Old 01-19-2008, 04:11 PM   eBay Motors  #10 (permalink)
Administrator
ob_1jr's Avatar
Yeah, that is what some of the other forums say...Talk to Mike L. (forum member) for good information on the allison and what he recommends. He is the allison guru on this and other forums.
SOLD
