Old 11-05-2009, 11:31 PM   eBay Motors   #11 (permalink)
GeorgiaDuramax
GeorgiaDuramax's Avatar
If yall dont mind me jumpin in, but what exactly does the water to meth injection do?
2001 Chevrolet Silverado 2500HD Duramax Diesel
6" Fabtech lift
Fabtech traction bars
20" Procomp Alloy wheels or 16" Weld racing
35" Mickey Thompson ATZ or 35" MT MTZ
AEM Brute Force intake
Edge Juice w/ Attitude w/ ATS overhead mount
MBRP 4" duals
PPE Boost valve
3 10" Rockford Fosgate subs
8000K HID low beams and fogs
GeorgiaDuramax is offline   Reply With Quote
Old 11-05-2009, 11:35 PM   eBay Motors   #12 (permalink)
D-MAX Mafia
Wide Open!!!
D-MAX Mafia's Avatar
The water and meth are atomized into the intake charge through two injectors thus cooling the air and the methanol acts as an additional fuel.
06 CC/SB LBZ
I got a D-MAX Baby!
Tuned with EFILive
D-MAX Mafia is offline   Reply With Quote
Old 11-05-2009, 11:40 PM   eBay Motors   #13 (permalink)
Jonsey181
Jonsey181's Avatar
Water meth injection can lower your EGT's and give you some added power, If you run straight water it will only cool your EGT's but depending on the mix of methanol 30% 50% 75& or 100% will claim to give you added power im not an expert on it but this is all to my knowledge the water adds higher pos. pressure and allows for complete combustion while added methanol is just another fuel added to the chamber
Eric: 2005 GMC 2500HD LLY
Jonsey181 is offline   Reply With Quote
Old 11-05-2009, 11:41 PM   eBay Motors   #14 (permalink)
Jonsey181
Jonsey181's Avatar
a little late i see
Old 11-06-2009, 08:59 AM   eBay Motors   #15 (permalink)
GeorgiaDuramax
alright, cool. So would this be beneficial only if you are pulling or running your truck hard?
6" Fabtech lift
MBRP 4" duals
PPE Boost valve
Old 11-06-2009, 09:22 AM   eBay Motors   #16 (permalink)
seth999
Duramax Forum Moderator
seth999's Avatar
the mix of methyl alcohol and water cool the intake air making it more dense so more air can enter the turbo/cylinder...the meth makes a more efficient combustion and helps burn the extra fuel (similar to NOS but not as hardcore)...then the remaining water turns to steam with high temps. causing a "steam engine" effect and raising cylinder pressure.
so yeah it will help out in all situations but there is just a greater need for it in high temp. applications...there should still be an increase in MPG and power no matter what, the #'s would just be based on the kit
DD
08" chevy 2500HD cc short bed LTZ
9" fabtech lift/AMP steps
burnt orange paint job
Transgo jr.--Ali is Burnt
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Snow Stage 3 Water/Meth
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
seth999 is offline   Reply With Quote
Old 11-06-2009, 11:05 AM   eBay Motors   #17 (permalink)
GeorgiaDuramax
Does this run constantly while the truck is running or just on the flip of a switch?
6" Fabtech lift
MBRP 4" duals
PPE Boost valve
Old 11-06-2009, 12:32 PM   eBay Motors   #18 (permalink)
Jonsey181
Jonsey181's Avatar
It is at the flip of the switch or some are preset when the switch is on it will wait till you hit a minimum amount of boost to shoot in some water/methanol
Old 11-06-2009, 01:18 PM   eBay Motors   #19 (permalink)
seth999
seth999's Avatar
^^yup...also they have the comp. controled units now with multiple injectors so they can run small amounts to compensate for low boost levels so you don't get pooling they help with the MPG even more so than regular systems
DD
Banks Intake
Old 11-09-2009, 10:05 AM   eBay Motors   #20 (permalink)
GeorgiaDuramax
what is the install like on these kits?
6" Fabtech lift
MBRP 4" duals
PPE Boost valve
