Alright then the other thing I can think of is oil lines? Are they in the same place from LB7 to LBZ and same with intercooler tubes? Sorry for all the questions guys Im just trying to get an idea on what to do.
an lly,lbz intake...either will work + fleece controler + downpipe and you should be about good to go..
but honestly its not gonna make any more hp..maybe like 20 tops its just gonna sound neat at idle like mine
20 wouldn't be bad when I want to pull in the stock diesel class. Stock LB7 motor with stock LBZ turbo thats stock right. No one around here would know the difference.
Feed line should work for both but the return tubes are different I believe. The intercooler tube on the hot side will work just fine, you could always do the banks tube as well.
__________________ 2002 GMC LB7
I might know someone who could do some welding for me to get a pipe to work. When you hear from Freddy let me know if you wanted to sell or do a trade for the turbo I would be interested.
i thought about doing this and then adding the MPI kit that uses the stock lbz turbo but in the end it would cost about the same or a little less than the big kit. so i figured it wasnt worth the trouble.
noone would probably know if you threw a cheeta on there either
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
