Old 11-05-2009, 07:45 PM   eBay Motors   #1 (permalink)
trost66
trost66's Avatar
Head stud install
This might be a dumb question but when you install headstuds can you do them one at a time with out taking head off or do you have to remove head. Thanks for your help
2004 lb7 with 6inch stack banks waste gate. KN air intake air dog 150 South bend dual disk clutch 6 speed manual.
AK5 and 45% over injectors on the way
EFI Live. Tuned by Idaho Rob
trost66 is offline   Reply With Quote
Old 11-05-2009, 07:46 PM   eBay Motors   #2 (permalink)
delong_1
truck for sale
delong_1's Avatar
i did mine one at a time, no problems doing it this way.
Nate
2 turbos, built trans, and some tuning.
delong_1 is online now   Reply With Quote
Old 11-05-2009, 07:49 PM   eBay Motors   #3 (permalink)
trost66
trost66's Avatar
Cool that is what I was hoping to here. Another question I have to replace all of my injectors. What injectors would you recomend. Was thinking about going a little bigger. wha is the pros and cons of going bigger.
Old 11-05-2009, 07:50 PM   eBay Motors   #4 (permalink)
delong_1
truck for sale
delong_1's Avatar
cons: more expensive, thats about it. pros: more power.
ddp nozzles are very reasonable, kennedy diesel, big dipper's also. there are seval that seem to get the job done.
Nate
Old 11-06-2009, 06:31 AM   eBay Motors   #5 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i would take a few precautions doing the studds one at a time like that.one is find out how much TQR is on the stock bolts then make sure you dont tighten the new ones past that point untill all of them are done then go from the center out a tighten them down to 140TQR and leave'em just like that..the last few HGs i did i tighten the stock bolts down to 140TQR and i dont worry about them,i had a set come loose when i tightened them down to specs! i stole the idea from a large Diesel mechanics shop in Columbus OH.
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 11-06-2009, 12:47 PM   eBay Motors   #6 (permalink)
delong_1
truck for sale
delong_1's Avatar
you really cant do it that way, they all need to be cycled 3-4 times to full trq. i did mine individually and i havent had any issues at all.
Nate
Old 11-06-2009, 12:53 PM   eBay Motors   #7 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
stock bolt torque is 120-125 and same with ARP.
Old 11-09-2009, 09:29 PM   eBay Motors   #8 (permalink)
500hp2500
500hp2500's Avatar
i would go ahead and pull the head and put new gaskets in. i done my dodge buy taking the head off but i had to pull the engine to do them and went ahead and done fire rings in the block
1996 dodge 2500 12 valve cummins 512/984 on dunbars dyno
squrit squrit
future dmax owner
500hp2500 is offline   Reply With Quote
