aftermarket fuel filter setups - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 01-03-2010, 01:20 PM Thread Starter
Ok, I'm just about at the peak of what I'd ever like to do to this truck performance wise. just your average run of the mill intake/exhaust/edge/ppe boost valve setup.
i had my injectors done by GM under warranty 50,000 miles ago and now ones going out on me again. I took it to GM with 14 days left on my warranty and they said #7 is flowing high but not out of spec ENOUGH to warrant me falling into the warranty replacement category. :censored me right?
I did try a full bottle of fuel cleaner (over the course of a few tanks of course) but it hasn't done anything, guess it was a little bit of false hope left in me. I have a feeling this all is contributed to me running micogard bullshit autozone filters. although having changed them every oil change probably helped, running them in the first place as opposed to the new GM revision filter had to have been the worst thing for my poor new injectors.
So I somehwat lucked out because obviously #7 is on passenger side. gonna buy 4 injectors and get to work on that side as the dealer said driver side still responds well as far as injector readings go. But once i'm done putting in these injectors, which fuel filter do i go with?
kennedy diesel recommends the dual filter setup and they seem extremely knowledgable. however i really like the idea of the bd kit wit hthe single large tractor filter on it due to a larger surface area of filtration. what does everyone here run? as stated in the beginning of my post i have no interest in gobs of power so items like aftermarket lift pumps probably don't pertain to my particular situation.
whats everyone here run for fuel filters/recommend? (i'm looking for something more than oem size filter in stock location can offer)
Stewart Leask is offline
post #2 of 14 (permalink) Old 01-03-2010, 01:48 PM
Crusher's Avatar
You should look into FASS & Airdog. There are several reports that state air is the biggest contaminate to diesel sys. I just bought the FASS HD-C10-150G primarily to protect the CP3 Pump & Injectors.
2006 Chevy 2500HD LT CCSB 4X4 Duramax LBZ;
EFILive V2 Tuned by IdahoRob, FASS HD-C10-150G,
BANKS Ram Air Intake + Super Scoop, Banks Boost CAC Tube, BD Exhaust Manifold, EGR Blocker, MBRP DP, 4" Turbo-Back Exhaust w/ Aero-Turbine 4040, PCV Reroute, Transgo Jr., B&M Racing Deep Pan, Pure-Power Filter, SunCoast Deep Filter Lock,
Autometer Ultra-Lite II - EGT & Boost in overhead. NCT/Bilstein Shocks, Sulastic Shackles, Kryptonite Tie-Rods, Cognito UCA & Steering Braces, Firestone Ride-Rite Airbags, Reunel Bumper, Open Country M/T, LINE-X, TruXedo Tonneau, Pro-Tech Toolbox, Pioneer FH-P8000BT, i-pod, Focal 165KF Frt & Rear, JL Audio 300/4 Amp, Focal 27KX Subs, Audison Amp, Rattle-Trap Xtreme.
Crusher is offline
post #3 of 14 (permalink) Old 01-03-2010, 01:54 PM
SDP
Scott@SDP's Avatar
This is what I use Perma-Cool 81794 Perma-Cool Fuel Filter/Water Separator Kits
Great price and filters down to 2 microns, can handle 90 psi too so its good for after lift pumps. I think IdahoRob runs them as well, and they come with the mitusa lift pumps.
Screamin Diesel Performance 360-417-9000 Scott@SDPtwins.com
Compound twin turbo kits with 3" y-bridge and coolant tank for all Duramax's
SDPtwins.com LIKE US ON FACEBOOK!
2016 2.8L Duramax Canyon with SDP Compound twin turbo kit and DSP4 tuning
2009 LMM SDP trans, SDP GT5541/GTX42 twins, 200% injectors, 2x Exergy CP3's, Socal motor, ATP tuned
2002 LB7 SDP twins, ATP tuned, stock motor 11.97@113mph 7,200lbs
2001 LB7 SDP Built transmission, Single SDP S475, ATP tuning
2006 LBZ Race truck build
Scott@SDP is offline
post #4 of 14 (permalink) Old 01-03-2010, 02:38 PM Thread Starter
i have such a hard time seeing how my truck would need the FASS systems (i've been eyeballing them for awhile), i just think its overkill for my application. could I run the perma-cool water seperator along with the BD remote mount filter and be good to go? or will i start taxing my stock pump pretty bad?
post #5 of 14 (permalink) Old 01-11-2010, 09:37 PM
HuskerDiesel's Avatar
HuskerDiesel is offline
post #6 of 14 (permalink) Old 01-12-2010, 11:15 AM
DSTRBD's Avatar
Airdog II is the way to go in my opinion. We sell quite a few of these units and everyone absolutely loves them. Easy install, great pump/filtration, and the best warranty in the business.
DSTRBD is offline
post #7 of 14 (permalink) Old 01-12-2010, 12:01 PM
XBoxLive: RenegadeDuramax
XtremeDMax's Avatar
Send a message via Yahoo to XtremeDMax
DURA MAXXX / bnkrupt... did I miss something? What happened?
2015 Silverado 2500HD CCSB LTZ Dmax
Originally Posted by TheStepChild View Post
You want your exhaust to be like a fart. You can't see it but you know the effects of it.
If you can see your fart you got problems. If you can see your exhaust ...
XtremeDMax is offline
post #8 of 14 (permalink) Old 01-12-2010, 12:08 PM
1911samcolt's Avatar
^^^^^x2 im lost
2005 GMC-ccsb-LLY-PPE standard-5" straight pipe-LBZ mouthpiece-auto meter sport comp II's-EGR blocker-PCV reroute-265/75/16 E rated Bridgestone Revo 2's-torsion keys-pac brake air bags
Project:1973/1979 F250 4X4 with a 7.3L IDI diesel
Old Ride:1996 F350 Powerstroke 4X4 aluminum flat bed 5" exhaust and chip
pictures: http://s898.photobucket.com/albums/ac186/1911samcolt/
1911samcolt is offline
post #9 of 14 (permalink) Old 01-12-2010, 12:12 PM
mijdirtyjeep's Avatar
Aftermarket filters are nice, and they might make your injectors last a little longer, but they will still fail eventually. Many are running extra filters and still have them fail. I am not discouraging you about getting one. IMO the aftermarket filters are cheaper to replace then the stock one and if they make it "stock" last twice as long it is not a bad thing. I am just saying that extra filters will not keep your injectors from failing.
Jim
mijdirtyjeep is offline
post #10 of 14 (permalink) Old 01-12-2010, 12:22 PM
XtremeDMax's Avatar
