| Gus, get a stubby handle 3/8" drive ratchet, about an 8" extension, and a deep well socket. Remove everything as you have done, and pop the compressor housing off (it gives you a little room) the turbo. Crawl up on the core support and get a flashlight, your going to have to work from the bottom up by feel, but you will be able to look in from the sides and see what you are doing. This is the easiest way I came up with to get that thing off, I've had it off a couple of times and it always took me about a half hour, with 20 minutes of it being spent removing the oil drain bolts.
__________________ 05 CC/SB HOUND DOG EXPRESS
Up on stands, broke down & being rebuilt a little at a time |
