Old 03-03-2008, 03:51 PM   eBay Motors   #1 (permalink)
Cummin_Get_Some
Cummin_Get_Some's Avatar
Angry My AK5 went boom 15 minutes after install!!!
Bought a used aurora 5000 turbo and kit, had new seals, bearings, and wheel put in it from a professional shop. Did the install this weekend. Started the truck checked all connections for leaks made sure everything was ok and it was, turbo spun fine. Let it idle for 10 minutes or so. Went to take it home, reved it up some it sounded awesome! Made it 1/4 mile down the road and got on it a little and BANG It wasn't even spooled up enough to here it whistle before it popped. My first thought was I left a boost clamp loose and blew a boot. Left the truck running jumped out looked at all the boots the were fine. Removed intake and the compressor wheel wasn't spinning so I shut the truck off quickly. Looked at the turbo and the wheel was locked up but no visible damage, but the nut that holds the wheel to the shaft was just sitting in the intake of the turbo. So Im completely confused. Any ideas of to what happend?
05 QC/SB, cummins/6spd, SBC DD, Gauges, SMARTY TNT/R stacked with Stg. 2 Dr. P, ARP Studs, 90horse injectors, Ats Manifold, 66mm Silver Bullet, Enterprise Cam, CIA, 5" exhaust into 6" stacks, II Dual CP3s, and Hamilton 110s.
Special thanks to BLACKOUT PERFORMANCE
The artist formally known as "6speedduramax"
Cummin_Get_Some is offline   Reply With Quote
Old 03-03-2008, 04:31 PM   eBay Motors   #2 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
I got your message today just didnt have any time to reply. That really sucks. Who did the rebiuld, who ever it was they absolutly should stand behind that, It wasent Antrim was it?
Mine- 05 RC/LB D/ZF-6-Twin turbos, twin pumps, Tripple clutch
Hers-04.5 CC/SB D/A Big turbo, Big pump, Big trans
runNADM.com
EFI Live By Ricky Bobby
Old 03-03-2008, 04:41 PM   eBay Motors   #3 (permalink)
TurboBeagleBuggy
SmokinAsset hates me
TurboBeagleBuggy's Avatar
I would be calling your rebuilder A.S.A.P. Gus, if it was done properly that nut should have never came off the shaft!
05 CC/SB HOUND DOG EXPRESS
Up on stands, broke down & being rebuilt a little at a time
TurboBeagleBuggy is offline   Reply With Quote
Old 03-03-2008, 04:44 PM   eBay Motors   #4 (permalink)
Cummin_Get_Some
Yeah! It was late at night when I finished so we didn't tear it off to see what happend. Were going to tomorrow evening and see what happened. I'll post what we find out. Everything seemed perfect til I went to take it home.
Old 03-03-2008, 04:45 PM   eBay Motors   #5 (permalink)
Cummin_Get_Some
Off topic but...What do I do with the A/C hose that goes overtop the turbo just leave it sit on the housing?
Old 03-03-2008, 04:53 PM   eBay Motors   #6 (permalink)
duramaxsandwich
duramaxsandwich's Avatar
that sucks man. i think the guys that re-did it owe ya a new turbo!
i've seen trucks with the ac line just sitting ontop of the turbo, but i need to figure out something to do when mine when the a5k gets here.
2001 GMC EC/LB black D/A
2.8 puller
Built Motor, A5K, twin Cp3, big injectors, 6'' stack.....u get the idea...
NO LIMIT DIESEL PERFORMANCE
duramaxsandwich is offline   Reply With Quote
Old 03-03-2008, 04:54 PM   eBay Motors   #7 (permalink)
IdahoRob
IdahoRob's Avatar
We drill a hole in the lip above and ziptie it up tight against that lip.
Sorry to hear about the troubles. Good luck
2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
EFI Live, Suncoast Dealer, Dmax Hotrod Parts
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 03-03-2008, 04:59 PM   eBay Motors   #8 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
I wrapped my AC lines in some heat wrap and they hang about 2 or 3 inches above the exh housing all is fine so far but probally with the higher hight of the a5 you might wanna zip them up!
runNADM.com
Old 03-03-2008, 05:00 PM   eBay Motors   #9 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
Yeah even when turbos self destruct the nut usually still has the end of the shaft in it!!
runNADM.com
Old 03-03-2008, 05:10 PM   eBay Motors   #10 (permalink)
Diesel Nut
Dang, that sucks! I hope they stand behind their work.
Diesel Nut is offline   Reply With Quote
