lb7 resonator - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 02-17-2010, 02:47 AM Thread Starter
tonymontana13's Avatar
lb7 resonator
I plugged my resonator to get more turbo whistle and made my truck sluggish till high rms what could cause this? Has anybody had this happen to them?
Gabe 23
03 lb7 crew cab short box
10 inch cognito lift,37 1350 20 ss m16, 20x12 956s, 4.56 gears
Pioneer door speakers and tweeters 7inch double din dvd 2 10' cvr zx750.1 amp
4 inch straight pipe turbo back with 6 inch tip
intake horn mod, afe stage 2 intake
Efi live dsp5-duramax tuner
PPE Stage 5 By Diesel DayDreamshttp://www.performancetruckproducts.com
tonymontana13 is offline
post #2 of 4 (permalink) Old 02-18-2010, 12:28 AM
Tow Master's Avatar
Maybe the plug is leaking causing low boost pressure. Start it up and use a quick short spray of starting fluid. If the engine RPMS jump thers a leak
Jason
Tow Master is offline
post #3 of 4 (permalink) Old 02-18-2010, 12:37 AM
beanpole209's Avatar
The only thing would be if it were leaking, or you unplugged something. It is pre turbo so the leaking problem would probably be interfering with the MAF. If you unplugged something, you would probably have a light on. my 2c
beanpole209 is offline
post #4 of 4 (permalink) Old 02-18-2010, 10:30 PM Thread Starter
So the plug wasn't sealing the hole tight enough than so air wouldn't get in
Gabe 23
