But would there be a difference from the strait pipe to 4" if you were towing?
Not a whole lot of difference....straight pipe got real loud in the cab around 2200 RPMs. The 4" MBRP with muffler is a little mellower, but there is a resonance in the cab all the time. Straight pipe was only a little louder than stock while cruising at about 2000 RPMs (about 70 mph for me).
4" turbo back MBRP exhaust
AFE Magnum Force Stage 2 Proguard 7 intake Kennedy Diesel Merchant Automotive My Photos
Check out the AFE or MBRP systems, we stock them both and they are the best value going for fit finish and options like cat back, front pipe back etc etc. Call us and we'll be glad to help you on them.
Mark @ DPPI
__________________ DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM WE GUARANTEE OUR PRICES! DISTRIBUTOR of MBRP EXHAUST SYSTEMS, EDGE PRODUCTS, AUTO METER GAUGES and MOUNTS, DiPRICOL GAUGES, SUPER CHIPS MICRO TUNERS, SMARTY, DIABLO PREDATOR, AFE INTAKE and EXHAUST SYSTEMS, PML ALUMINUM TRANS PANS and DIFF COVERS, VAN AAKEN PERFORMANCE MODULES, TS PERFORMANCE, POWERSLOT & HAWK BRAKES, FASS SYSTEMS, SUNCOAST TRANSMISSIONS, BOSCH , SNOW WATER METHANOL SYSTEMS, BULLY DOG PRODUCTS, ARP Studs, FLUIDAMPR,STANADYNE ADDITIVES.
Mark @ DPPI
ill check it out.......ive looked at the MBRP but ill look at AFE too.
I like the MBRP 5in alot better then the stock strait pipe i had!
__________________ 04 LB7 Ext. cab short bed.
5 in. MBRP exhaust Quadzilla 215 Stealth 2
Super Diesel sleeves and centerlink
H2 wheels 315 BFG All terrains
Super Diesel lift pump kit
EFI Live from McRat Racing, Currently tuned by Caleb(05lly)
Loosing the cat in your case will be a huge egt improverment 4'' even more since you are running a bigger program!
Thanks for the info on loosing the cat. I won't be running the big program while towing and will still probably run 4" when I get the money to do so. you had asked if the Bully Dog read DTC's, yes it does. If I had to do all this all over again I think I would go with EFI live because of the almost unlimited programming possibilities. The BD was a good one for updates and all but there is no forum for help.
__________________ Bruce White 2005 GMC Crew Cab 2500 HD Leather W/ DVD, Two Way Remote Start
K&N Air Charger, Edge w/ Attitude,,,
Saving my pennies for more black smoke
I still have my stock strait pipe system if anybody close would want it. Id give it away. Its for ext. cab short bed
