Hey, I have a 03....w/ standard ppe. I am kinda sick of switching settings for different applications. I am pulling 5,000 or less. To get best fuel economy, should I leave it in econ and use the tow switch or go to the tow setting ?
If I leave it on the tow setting, will I be getting worse fuel when not pulling?
can someone give me some guidelines..... thanks!!!
for the most part when my truck was stock other then the PPE and such i ran level 2 and that seemed to be the best all around.
__________________ James
I always use tow/haul. Helps save brakes on the truck. But you just have to play with it and find what works Best for you.
__________________ 2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058(Fleece Performance), SC Case Brace, 68mm Cheetah, EFI Live, HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
Ya I agree with leaving it on level 2. The only major thing that could happen is the EGT's could start to climb and get high. At 1350 degrees the aluminum heads start to warp so thats the point you shouldnt go past.
So as long as you have a pyrometer gauge you'll be fine. Id still use the tow/haul mode to help with firmer shifts and downshifts when towing
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
