Old 06-29-2008, 09:06 PM   eBay Motors   #1 (permalink)
2001_STACKEDNLOVINIT
Points: 14, Level: 1
Points: 14, Level: 1 Points: 14, Level: 1 Points: 14, Level: 1
Activity: 0%
stacking chips questions
I have a 2001 duramax and i have the Edge ez amp on stage 4 stacked with the predator chip. It runs VERY well. Is this a bad combo for the engine?
2001_STACKEDNLOVINIT is offline   Reply With Quote
Old 06-29-2008, 09:31 PM   eBay Motors   #2 (permalink)
psyco66
Points: 3,636, Level: 25
Points: 3,636, Level: 25 Points: 3,636, Level: 25 Points: 3,636, Level: 25
Activity: 0%
psyco66's Avatar
I do not know anyone that stacks chips on Daxes. There is no need to stack on a Dmax when you run a good chip. There is to much of a change of adding to much timing as stuff like that. If I were you I would sell both of those and get a PPE or EFI live. My choice would be EFI live.
John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me.
NO TALKING JUST LINE IT UP
psyco66 is offline   Reply With Quote
Old 06-29-2008, 09:39 PM   eBay Motors   #3 (permalink)
Activity: 0%
Well when i try to download a programmer to my truck (the port under the dash) it says pcm locked. and kicks me out of the down load every time. any Ideas what that is? thanks guys
Old 06-29-2008, 10:20 PM   eBay Motors   #4 (permalink)
daddysLBZ
Highway travler!!
Points: 6,278, Level: 33
Points: 6,278, Level: 33 Points: 6,278, Level: 33 Points: 6,278, Level: 33
Activity: 63%
Activity: 63% Activity: 63% Activity: 63%
daddysLBZ's Avatar
The prog ya have now may not allow fer stacking...Just a thought.....
MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350
WORK RIG:03 YukonXLHypertech tuned!!310k miles!
The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
Old 06-29-2008, 10:23 PM   eBay Motors   #5 (permalink)
Activity: 0%
I removed both chips and tried to install a program, still same code. pcm locked. I dont know what to do. I took it to chevy they programmed everything back to stock and still same thing
Old 06-29-2008, 10:28 PM   eBay Motors   #6 (permalink)
psyco66
Activity: 0%
psyco66's Avatar
What tuner are you tryin gto load. Are you sure it is not the tuner that is locked. Is it a used tuner.
John
Old 06-29-2008, 10:42 PM   eBay Motors   #7 (permalink)
Activity: 0%
i tried installing a hypertech, and a brand new bully dog. they downloaded fine on my buddies truck after we tried on mine. then we uninstalled them on his truck and still no go.
Old 06-29-2008, 11:45 PM   eBay Motors   #8 (permalink)
ob_1jr
Super Moderator
Points: 6,371, Level: 34
Points: 6,371, Level: 34 Points: 6,371, Level: 34 Points: 6,371, Level: 34
Activity: 5%
Activity: 5% Activity: 5% Activity: 5%
ob_1jr's Avatar
it sounds like there may have been something done to your ECM. Are you sure that you are going to the ON position on the key and not accessory (have to ask...Im sure you are since it worked on your buddy's truck). I know with some trucks you have to pull fuzes....do you have onstar??? I don't know if it was an option on your truck.
So, you were able to put your truck back to stock with the predator? try unpluging the edge (it is the inline box right?) and plug your harnesses back in and try again. I don't know much about the edge ez, but I know that edge juice w/ attitude stacks just fine with the predator.
Personally I am using the TST powermax and diablosport predator and it works pretty good. The TST came with my truck, so I haven't decided to get rid of it.
4" turbo back MBRP exhaust
Kennedy Diesel
Merchant Automotive
My Photos
Old 06-29-2008, 11:55 PM   eBay Motors   #9 (permalink)
daddysLBZ
Highway travler!!
Activity: 63%
daddysLBZ's Avatar
I know on my prog,ya have to reflash the truck back to stock,before ya can use on another truck,I beleive most tuners today are VIN locked; means ya can not use the same tuner on more than 1 truck at a time,always go back to stock before using a tuner in a diff machine..
