Old 07-08-2008, 07:20 PM   eBay Motors   #21 (permalink)
Johnasara
Yeah, That guy!!!!!
Johnasara's Avatar
Hey supper I saw the spread sheet and wanted to CRY
4" DIAMOND EYE EXHAUST,
DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
Old 07-08-2008, 07:31 PM   eBay Motors   #22 (permalink)
New2DMax
New2DMax's Avatar
Kind of a dumb question, now that the milage is up, but when you changed to the 265s, did you reset the tire height in your computer? My programmer asks for this as an option before I get out. That will change those numbers quite a bit. That old geometry problem of circumference.
I want a copy of that spreadsheet. I write down every fill and it would be nice to capitolize on your Excel prowes.
02' Chevy Crew Cab
Short box 4X4
BullyDog PowerPup
4" MBRP Down Tube back
KoolVue Tow Mirrors
Fifth Wheel & GooseNeck
New2DMax is offline   Reply With Quote
Old 07-08-2008, 08:08 PM   eBay Motors   #23 (permalink)
Supper
Supper's Avatar
If that is because of the fuel economy, lets see some proof as to why. I hold no delusions when it comes to fuel economy, have seen too many "miracle motors" not do crap.
If its because of the fuel price, well, welcome to the club
2003 GM 2500HD Auto CrewCab Short Bed 130,000 miles. No longer bone stock. 5" turbo-back straight pipe & PPE Standard Xcelerator, transmission and suspension on its way once I can afford them :cool
Supper is offline   Reply With Quote
Old 07-08-2008, 08:14 PM   eBay Motors   #24 (permalink)
Supper
Supper's Avatar
PM me your email address and I'll shoot you a blank copy.
The reason I really like it is I set up a self calculating averages and totals page, takes all the data from the mileage page and figures everything for you. Be careful though, the "Total spent on fuel" section gets depressing sometimes.
Old 07-08-2008, 08:45 PM   eBay Motors   #25 (permalink)
mromoney
mromoney's Avatar
I have a 04 LB7 and i'm getting around 15.75 to 18mpg. city and highway. lead feet and grandpa. the best I had was 18.8mpg all highway doing 75-80mph.
2004 LB7 Crew Cab 4x4 SLT
Dyno stock numbers 454.3rwTrq and 246.8rwhp boost 22psi EGT 1100
23.2mpg @70mph hwyAmsoil-Air Filter, motor oil, both Diff's, Tranny, Tranfer Case Autometer C2 0-35boost and 0-1600temp gauge Cooper STT Tires 285/75-R16
PPE Standend set on 40hp/160trq and Boost valve Single Flowmaster 4" with a SS 5" tip, two Interstate battery 800 CCA
mromoney is offline   Reply With Quote
Old 07-09-2008, 09:59 AM   eBay Motors   #26 (permalink)
gr8shot
LMM'N
gr8shot's Avatar
One thing nobody has mentioned is brakes. Check your brakes and make sure you don't have a stuck caliper. It's happend to me before. But it also told me it was stuck by warping the rotor. And it was a PITA to get off!! If you got a caliper thats draggin, it'll pull your mpg's down a bit.
Another thing that gets a lot of people another 1 mpg or so is switchin to synthetic fluids. There's been tons of threads about it, but tons of people say that once they switched over all their fluids to syn, they gained about 1 mpg. Its not much, but it'd be piece of mind, and longer change intervals too, which save $$ in the long run.
Old 07-11-2008, 06:29 PM   eBay Motors   #27 (permalink)
88_trex
i know this is going to sound wrong but all of us with ppe's run them on the highest setting! seems the higher you raise the setting the better it does on fuel (as long as you keep the right foot light) you might give it a try.
88_trex is offline   Reply With Quote
Old 07-11-2008, 07:13 PM   eBay Motors   #28 (permalink)
ccvt98
ccvt98's Avatar
i noticed on mine ,when i changed to the 295/70 tire size , and use my programmer to correct the speedo, it set it way off, using my GPS @ 60mph the truck speedo read 56mph and when i programmed with my superchip ,it changed it to read 64 mph , which will make the DIC read real good on mileage..I changed it back, since it would be added excess mileage to the truck..
2007 GMC 2500HD Classic CC 4x4
2006 H2 Wheels w/Nitto Terra Grapper 295/70/17
Banks Power Package w/PDA
REAL TRUCKS DON'T USE SPARKPLUGS
Toys:
2001 30' Keystone 5th Wheel Camper
2001 29' Fountain CC Power Boat
1982 Kawasaki KZ1100 A2 (new project)3/14/09
1980 Kawasaki KZ750 LTD (restored)
1962 VW Bug *in process of restoration*
1932 Ford Model B * restored* Stock
ccvt98 is offline   Reply With Quote
Old 07-11-2008, 08:59 PM   eBay Motors   #29 (permalink)
cloudgmc
wow some of u are getting way better miles then me. im getting 12.7mpg. i thought that was normal for a diesel truck. also i was told that when driving hwy if ur towing or not u will mostly see the same mpg cuz the power the truck has. i do have an intake and exhust but with the cat, no programer, at least no yet. i have a 05 lly crew
cloudgmc is offline   Reply With Quote
Old 07-11-2008, 10:07 PM   eBay Motors   #30 (permalink)
n0useforaname
Knows your Mom
n0useforaname's Avatar
You should be seeing at least 15 to 16 MPG. Read some of KillerBee's articles on how to fix the cooling issue with the LLY.
LIFT: Ready Lift Leveling Kit
