i have a 03 with PPE hot+2 i think i need more fuel, i got a taste of the power and want more getting a stage 3 CP3 and fass would solve my power needs right, or what direction should i look at.
__________________ 2003 chevy lb7 duramax 3500
6'' stacks,AFE,PPE hot+2,mp-8 boost fooler, gauges, built tranny, FASS 150,
all thanks to Wally from FTEDiesel
SOLD
2004.5 GMC lly duramax 2500/ZF-6
optic gauges, PPE hot+2,south bend dd,
6'' Inch Black Stacks, and black y-pipe:cool
super diesel lift pumpneed a FASS
LBZ mouthpiece. AFE intake
WISH LIST TS-MP8,with with race vavle
Huge thanks to Wally From FTEDIESEL
The Fass and Modied CP3 will help you out in the fuel delivery part, but now you will probably find the EGTs out of control and the transmission will be very upset with you. The Bully Dog shift kit is nothing more than a rebadged Trans Go Jr kit. To install the Full trans go kit you have to tear the complete transmission down. You have to change out the piston return springs on the C1 clutch pack, and there are several valves and springs that need to be changed in the Converter housing. I would look at the Suncoast Stg IV first. Get the transmission set up to handle the power, then put the power to it.
On the EGT issue, I would like to see a BD Supermax Turbo and a BD Full bore exhaust manifold to get the air flowing and get all that fuel burnt.
You will probably also have to shim your rail.
See, that first shot of power is the cheap shot. The initial upgrade is always the easiest and cheapest. Now you have considerably more work to do before you can add any more fuel, but if done right, you should wind up in the 450-500hp range no problem.
__________________ 2007.5 4x4 Dually, Summit White- Grey Leather,PPE,Transgo, Jr.5"Filter Back, 6" Tip. Weatherguard Box,16" Moto Metal 953's Firestone 235-85-16 Transports. ICI to the Rear, Turning In. All Emblems are Removed !!!! 2" Drop Sulastics and Bilsteins, Tinted Windows, Amsoil, Front to Back !!
i would look at adding the second fuel delivery line from the pump to the rail and doing bigger rail fittings along with the Fass but before doing the bigger CP3 you mite wanna do some EGT's lowering or else your pistons will be TOAST..
Water/Meth kit will help alot along with a turbo upgrade and a BD Manifold along with a bigger inercooler but building your tranny will be your next step.
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
