p1404 egr help - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 02-26-2011, 09:51 PM Thread Starter
p1404 egr help
OK my buddy has a 03 LB7 with a TST programer and he is getting codes P0380 and P1404. Can take care of the P0380 but need help with P1404. How can we fix the problem? Put a blocker plate, but then how to get rid of code? Full delete? Where to buy the kit? Or just buy new parts and replace the bad ones keeping it stock. Thanks for your help and insight, need to get this taken care of.
duramax-upnorth is offline
post #2 of 12 (permalink) Old 02-26-2011, 10:25 PM
DIESELbowhunter's Avatar
my PPE programmer took care of any egr codes i threw.. Do you know why he is getting those codes in the first place?
05 LLY
Robs EFI Live
Dipper trans/ML Converter
Studs
4094
AD 165
Zone 6"/35s
DIESELbowhunter is offline
post #3 of 12 (permalink) Old 02-27-2011, 06:43 PM
audiomixer's Avatar
Yeah do you have emissions testing there? Id get EFI and be done with it.
Chevrolet '16 2500HD 4WD LTZ CC D/A LML Deep Ocean Blue, stock.
GMC '04 2500HD SLE CC D/A LB7 SB Summit White, LineX, Nicktane, JK headlight harness, JK fuel pump and harness, Banks exhaust, EFI Live, intake horn mod, Suncoast 6 speed conversion, injectors at 112,265 (#8 again at 136K), ...and all 8 again at 168,368.
VW '01 Bug TDI 6 spd ERF manual, 11mm IP, DLC 520 injectors, Malone stage 2 tuning. My FUN summer driver.
Fuel mileage? Who cares, its a diesel.
audiomixer is online now
post #4 of 12 (permalink) Old 02-28-2011, 01:05 PM Thread Starter
no emissions testing here. He really wasn't looking to spend money on efi so not sure. He said the check engine light came on the other day and he brought it over and i scanned and those are the codes I got
post #5 of 12 (permalink) Old 02-28-2011, 10:58 PM
audiomixer's Avatar
P1404 means that the EGR is not closing properly. Could be over boost in access of 25psi or perhaps one of the solenoids is stuck open and not shutting off the vacuum to the EGR valve or the EGR valve itself is screwed up. This system is a nightmare. Is the truck lacking power or smoking more than usual? The only fix is to diagnose the system and repair it or EFI live to disable it. There is no way to cheat the system without getting a code. In your case if you decide to disable it, use a blocker plate for insurance. LLY blocker plate will work.
Somewhere on this site there is a schematic with pics if your buddy needs it.
post #6 of 12 (permalink) Old 03-01-2011, 06:32 PM Thread Starter
No the truck isn't lacking power and doesn't smoke any. If he decides to block the system is there anyway to disable the code without EFI?
post #7 of 12 (permalink) Old 03-01-2011, 06:56 PM
JMootz's Avatar
i have the same code along with a couple others and was told that i need efi live to take the code out after i did a egr delete kit or just deal with the code or check engin light butt i didnt get a check engin light did you block the egr if not i have my used one for sale dealer wants 300 for a new one ill take 125 for mine shipped
04.5 ccls sb LLY 4" MBRP exhaust from turboback AFE Bladerunner mouth piece, edge insight CTS monitor, ddm HID hi/lo de down pipe egr delete pcv reroute bills custom stage 3 intake,tow mirrors,billet fuel door,tie rod sleves. BD exhaust manifold .dsp5 buit tranny tune from duramaxtunner thanks to Nick&Bob1-815-861-5807[/COLOR].built tranny g max pac 5 thanks SHANE!air dog 165.B D intercooler Afe in and out pipes
JMootz is offline
post #8 of 12 (permalink) Old 03-01-2011, 07:00 PM Thread Starter
JMootz, so you put the egr delete and didn't get the code? Where did you get you egr delete kit?
post #9 of 12 (permalink) Old 03-01-2011, 07:09 PM
JMootz's Avatar
no i still get the codes of p1404 p0401 and p0405 that come up on my edge insight cts butt no check engine i had husktorf diesel do the egr delete they said dont worry about the codes unless you want them gone then you need efi or a diesel shop/dealer to into the ecm and tell the ecm its blocked/deleted
JMootz is offline
post #10 of 12 (permalink) Old 03-01-2011, 07:53 PM
audiomixer's Avatar
The point is you will get codes. Will it hurt performance? No. But if you want to do away with CEL and codes, EFI live is about the only way to deal with it. There is no kit.
