Help replacing inner tie rod end. - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 09-28-2008, 09:09 PM Thread Starter
wildturkey_hunter's Avatar
Question Help replacing inner tie rod end.
Can anyone explain how to replace the inner tie rod on my 05. I've got a lot of play in it the outer seems to be fine. I can see the rod moving in and out of the rubber boot about a 1/4" and a noticeable clunk sound when I shake the tire back and forth. They dont look like the old tie rods that you used to just take the nut off and smack with a hammer so any help would be appreciated.
2005 Chevy 2500 4X4 LLY,LT,CC Dean 285/75/R16
T-Bars Cranked to the MAX
MBRP 4" DownPipe Back
Bully Dog Power Pup
Auto Meter Ultra Lite II
Boost And Pyro on A Pillar
Plugged Resonator:ar15
wildturkey_hunter is offline
post #2 of 7 (permalink) Old 09-28-2008, 09:33 PM
VAGITARIAN :)
daddysLBZ's Avatar
Might get a puller to help out.[steady even pulling takes it off]Don't beat the threads,if you have to,put the nut back on top,then gently tap with a wood block..
2006 GMC 4x4 CC/SB/sle1/LBZ**312,000 miles!!** PPE HOT+2 225 TUNE beeeyotch:-)AutoMeter egt/boost Suncoast 5 trans w/1056TC!tsktsk,billet in/out shafts/MagHytec pan!!,M/A built T-Case,4 in.str8piped,5%tint all around......
2007 Chevrolet 4x4 cc\sb,lbz.......SOLD to blunova
Also, I speed and don't come to complete stops at stop signs.
''don't sweat the petty things,pet the sweaty things''
Click below/pictures of my junk!!
http://www.duramaxforum.com/forum/vb...do=hall&u=8415
daddysLBZ is offline
post #3 of 7 (permalink) Old 09-28-2008, 10:41 PM Thread Starter
Here's a pic. Idont think a puller will do it. The outer tie rod end screws on to the skinny end. The other end is what's got me confused. I guess maybe it just screw in to the center link?
Bully Dog Power Pup
post #4 of 7 (permalink) Old 09-28-2008, 11:13 PM
Tow Master's Avatar
The nut on the inner part shows on the truck. IIRC loosen them with a wrench then they just unscrew from the truck! If you do replace it make sure you get a alignment afterwards! Heck, call the local alignment shop. They might throw it on there while there at it!
Jason
Tow Master is offline
post #5 of 7 (permalink) Old 09-29-2008, 08:08 AM
duramax-rob's Avatar
If I'm not mistaken, there is a special tool that you use to take the inner tie rod loose with. It kinda looks like a long tube with interchangeable crows foot on the inner end. you might be able to borrow one or rent one. Last time I checked 5 years ago they were about $90. Might try auto parts store or rental center. K-D I think make one.
duramax-rob
__________________________________________________ __________________________________________________ _
2001 Chevy 3500 CC Longbed Dually 4X4, 6.6 Duramax, PPE Standard, Magna Flow 4" Exhaust, Gooseneck hitch, 32' Gooseneck Trailer, Allis Chambers Backhoe
Some's good, More's better, Too much is just enough!!!!
http://www.alligatorperformance.com/ http://www.alligatorperformance.com/
duramax-rob is offline
post #6 of 7 (permalink) Old 09-29-2008, 09:48 AM
Kyle@XDP's Avatar
jack the truck up and use a good sized pipe wrench on it and it'll come out. mine was a pita and i had to take the whole center link out and put it in the vise.
This username is no longer active. Please send all PM's to Xtremediesel
Ask About our Daily Specials and Discounts for Forum Members
Banks, Edge, PPE, Hypertech, ATS, BD Diesel, Silverline, MBRP, Magnaflow, Mag-Hytec, Air Dog fuel systems, Titan and Transferflow fuel tanks, and many many more.[/CENTER]
Kyle@XDP is offline
post #7 of 7 (permalink) Old 09-29-2008, 09:54 AM
I just replaced my tie rods on my 05, i just grabbed the centerlink with a visegrip, held it still and used a big ol adjustable wrench and it broke the tie rod loose. Was a pain though
05 lly EC SB, EFI Live (Moonshine), Big Dipper trans, raptor 150, 5" mbrp turbo back single 7" stack, MBRP 3" downpipe, S&B intake, , Cognito 7-9 set at 9", 37" terra grapplers, Cognito HD tie rods, AFE Bladerunner, EGR blocked, BD exhaust manifold, MBRP hot side intercooler pipe, ATS diff cover, autometer digital boost/pyro
NJDuramax is offline
