Power steering pump removal - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 08-30-2011, 04:58 PM Thread Starter
I have searched and searched everywhere and I cannot find anything. I have taken the three bolts off of the front left of the power steering pump and the one off of the back bracket. It is wiggling but will not come loose. It looks like there may be one more line on the back with a bolt connecting it but I cannot reach it. What am I missing. Thanks in advance
bmwmotorsports is offline
post #2 of 10 (permalink) Old 08-30-2011, 05:06 PM
Vrabel's Avatar
there's 2 on the back
R.I.P.
2001 Chevy CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline
post #3 of 10 (permalink) Old 08-30-2011, 05:06 PM
Vrabel's Avatar
do you have wheel well pulled? it a whole lot easier.
R.I.P.
Vrabel is offline
post #4 of 10 (permalink) Old 08-30-2011, 05:07 PM Thread Starter
i saw the close one I will take the wheel well off and look
post #5 of 10 (permalink) Old 08-30-2011, 05:17 PM
Vrabel's Avatar
did you take nut off back of pump? or bolt out facing block? That nut holds pump to bracket that's bolted to block. There's 2 about 2 in. apart vertically. Leave the nut on and remove 2 bolts.
R.I.P.
Vrabel is offline
post #6 of 10 (permalink) Old 08-30-2011, 06:59 PM Thread Starter
Got it now. Went into it blind. Couldnt find anything anywhere. Might need to make a writeup.
post #7 of 10 (permalink) Old 08-31-2011, 11:59 AM
DarkCharisma89's Avatar
I would appreciate that, I have a leak in mine I am going to try to repair, soon.
Just gas burners now
DarkCharisma89 is offline
post #8 of 10 (permalink) Old 08-31-2011, 12:47 PM
ejevans72's Avatar
Just replaced mine in a parking lot the day after I broke down.... really wasn't too bad, just messy.
Took about 4 hours once I started and some of that was trying to find a place to press the new pulley back on.
I pulled the wheel liner, the intercooler pipe, the fan cover trim, pulled the battery ground mount...and I think that was it. I would have to go look at it to remember anyhthing else I may have pulled off.
Be sure to install your new O-rings!
- 2001 Silverado 2500HD Crew Cab / Long Bed -2WD
Stock LB7 / Allison with 888,000miles
(112,000 miles to go!)
*** Thanks to Lincoln Diesel for their service and help in keeping my DMAX running stout! ***
ejevans72 is offline
post #9 of 10 (permalink) Old 08-31-2011, 12:58 PM
Sweet, doesn't sound too bad. I have a press and pullers, so hopefully that makes things easier. Thanks!
post #10 of 10 (permalink) Old 08-31-2011, 04:44 PM
I just brought my new pump to the dealer and they pressed the pulley on/off for around $20.
After that it's pretty much just a messy job......helps to have line wrenches for the P/S hose fittings though.
MTL_Dmax is offline
