05 4500 topkick - Chevy and GMC Duramax Diesel Forum
post #1 of 17 (permalink) Old 09-01-2011, 06:06 AM Thread Starter
Exclamation 05 4500 topkick
got a 05 4500 topkick . had problem with it cold starting just crank and crank . had to give it a little spray magic fires right up and runs fine . took to dealer said code P1550 witch is for the FICM they reset computer .it would fire up after u cranked it for a while . did not replace ficm . now it will not start cold or hot with a little spray of either . but it runs fine after that ...
jivemother33 is offline
post #2 of 17 (permalink) Old 09-01-2011, 06:08 AM Thread Starter
i have unpluged and repluged conecters look for bad wires all seems good the dealer also said not fuel prime problem ,primer stays solid , truck has 50,000 on it
post #3 of 17 (permalink) Old 09-01-2011, 06:10 AM
mcle6103's Avatar
stop using the starter sprays you're going to blow the motor up.
Anyways dads 03 4500 never liked starting in the cold. still don't know why.
Sam - 08 LMM rclb - PANDAMAX
Built trans
Deleted
Willis Tuned
305/50/20
uppipes & manifolds
10mm, 60s, Billet 475 single
mcle6103 is offline
post #4 of 17 (permalink) Old 09-01-2011, 06:14 AM Thread Starter
i ment cold like motor not warm its 75 out now wont start evin after u drive for hour u shut it off it wont fire back up with out little help . i know its bad for it but its a company dump truck needs to go to the job make money we just leave it runnin . i am going to try a ficm but they are pricey for a new one
post #5 of 17 (permalink) Old 09-01-2011, 06:18 AM
mcle6103's Avatar
Oh ok gotcha I thought you mean like 30 degrees lol Sorry I'm not much help on this issue. FICM might be the only way to go.
Built trans
Deleted
Willis Tuned
305/50/20
uppipes & manifolds
mcle6103 is offline
post #6 of 17 (permalink) Old 09-01-2011, 06:27 AM
Administrator
jc1843's Avatar
The truck does not have a fuel pump-- did you pump the manual primer on the fuel filter housing--?? If the seals are bad in the housing, it will allow air into the fuel system, and not start. Try pumping the primer and then open the bleeder screw to let air out. Then close the bleeder and pump again. The bleeder screw is next to the pump and is made of plastic-- be careful-- it will break easy.
Inspect the FICM wire harness at the passenger side of the alternator. The harness is tied down with a zip tie, cut the zip tie, open up the plastic loom, carefully check for bare wires. The harness and wires get cut, and sometimes short to ground, by contact with the sharp corner of the FICM bracket. Repair, and insulate with a piece of heater hose.
This is a common problem for the LLY engine. Everyone that has a LLY should check this now!
jc1843 is online now
post #7 of 17 (permalink) Old 09-01-2011, 06:30 AM Thread Starter
the primer is solid still got good prime . i believe it is an electrical issue
post #8 of 17 (permalink) Old 09-01-2011, 06:42 AM
Administrator
jc1843's Avatar
Then check the wire harness at the alternator--I do not know if the 4500 is the same as the 2500/3500 trucks, but that can be a problem.
Check for codes.
post #9 of 17 (permalink) Old 09-01-2011, 06:49 AM Thread Starter
thanks ya i need to dig into it
post #10 of 17 (permalink) Old 09-01-2011, 07:01 AM
Markymark's Avatar
If you got fuel, it is an electrical issue, Like JC said, check each individual wire in the harness. mine went bad. maybe I should just start doing a cut and paste as well.
Mark
2005 4x4 3500 SRW CCLB LT, 120K+
4" MBRP SS Cat back, aFe MP
Nitto Terras on 17" Moto Metal 950
Markymark is offline
