Duramax Diesel Died - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 12-02-2011, 07:40 PM Thread Starter
Duramax Diesel Died
My 04 duramax died on me while idling in the drive thru at the bank i pulled it back to my house thinking its the fuel pump. What other things should i check before i go to tearing stuff out
weimarchevy is offline
post #2 of 13 (permalink) Old 12-02-2011, 07:54 PM
it stinks and whistles :)
Brennan's Avatar
9/10 you lost your prime, Crack the bleeder screw, push the big silver button on the filter head a few times, tighten the bleeder screw and start the truck. fyi we dont have fuel pumps
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #3 of 13 (permalink) Old 12-02-2011, 08:10 PM
05greendmax's Avatar
pump ur prime on top of ur fuel filter
2005 ccsb hunter green
rip old motor
(fully stock)
motor going in
huge thanks to Dustin and robb at (ATP)
could not have donr this with out your help
hope this new motor holds 500hp this time
05greendmax is offline
post #4 of 13 (permalink) Old 12-02-2011, 08:24 PM
Earnhardtfan's Avatar
Might need to change you fuel filter and/or rebuild the filter head. Sounds like you lost prime or finally plugged your filter.
Justin 2001 LB7 Silverado 2500HD LT CCSB 4x4.
EFI Live by Idaho Rob, 443K+ and rolling, Undercover Bed Cover, Vortex spray in bed liner, Odyssey Extreme Batteries, Westin steps, Bilstein Shocks, Road Master Active Suspension, M/A Pump Rub Kit, PPE Trans Cooler, MBRP 5" Exhaust, Edge Insight CTS, K&N drop in filter, AirDog II 100 w/ CAT 751, LLY FF Housing w/ Racor, Running on LMM Blacked out Wheels & Michelin LTX M/S2 tires.
ADRENALINE TRUCK PERFORMANCE
Lincoln Diesel Specialties
Merchant Automotive
Earnhardtfan is online now
post #5 of 13 (permalink) Old 12-02-2011, 09:23 PM
viejajefita's Avatar
4 out of 5 dentists agree that you might need to fix the primer on top of fuel filter housing. Easy and inexpensive, at least on my 06.
'06 2500 HD cc 4x4 Allison trans
Edge Evo Race level 2
265/75-16 BFG's
LBZ w/200k+ seen as high as 21mpg and as low as 8mpg
PPE free airbox mod from DIY sticky Firestone bags married to Ride Rite comp and gauge
Clinton lied. A man might forget where he parks or where he lives, but he never forgets oral sex, no matter how bad it is.
Barbara Bush
viejajefita is offline
post #6 of 13 (permalink) Old 12-03-2011, 07:11 AM Thread Starter
i can push that primer a while and it will start. but it only runs for about two minutes than it dies. cant keep it running. any suggestions
post #7 of 13 (permalink) Old 12-03-2011, 07:27 AM
Brennan's Avatar
Either you got a fuel system leak or you needs to rebuild your liter head, might e worth it to replace the bleed screw?
06 lly,
air dogII 165
Brennan is offline
post #8 of 13 (permalink) Old 12-03-2011, 07:33 AM
born country
Dmaxryan10's Avatar
rebuild filter head had an 01 do the same thing!
it's easy just o- rings.
NEW TRUCK- 2006 LBZ cc/sb loaded southern coach, smoky mountain sportsman edition, 20" black hostile havoc's, 305/50/20 nitto trail grapplers, EFI LIVE by rob at ATP performance, 5" exhaust, transgo jr, egr blocked, pcv rerouted, isspro ev2 gauges, tinted windows, just gettin started!
Dmaxryan10 is offline
post #9 of 13 (permalink) Old 12-03-2011, 08:11 AM
Administrator
jc1843's Avatar
Do you have a LB7 or a LLY engine-? An 04 can have either.
Check the 8th number in the VIN-- a LB7- "1" a LLY will have a "2"
The filter heads are the same, but there are other differences which may cause problems.
jc1843 is offline
post #10 of 13 (permalink) Old 12-03-2011, 10:22 AM
I just went through the same thing,or rather,"am" going through the same thing right now.My filter housing was cracked,from what I do not know,but you can get the whole unit,filter,canister,housing,and all for GM for about $160.00.Have the last 8 of the VIN ready when you call.
Papaken52 is offline
