Large Coolant leak - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 01-03-2012, 09:32 PM Thread Starter
Large Coolant leak
2004.5 2500hd cc 134kmiles duramax
I have a large coolant leak while truck is sitting not running...
I just got the truck noticed heater not working that well...
Noticed large pool of coolant in 4 hours...
Leaking on passenger side near wheel well...
Any direction or ideas would be great... It was dark when I saw it so I will look for the easy fixes in the morning.
Thanks for the help this is my firzt duramax, always had powerstrokes... Hopefully this is not the future of the new truck.
Thanks for the help guys,
Jason
904BUILDER is offline
post #2 of 19 (permalink) Old 01-03-2012, 09:56 PM
lmmduramax's Avatar
Im sure it is just a dry rotted hose or loose fitting. keep us posted and oh yeah Welcome!!
Brant:
Built & Tuned by Blackout Performance
Black 2008 GMC ccsb
Built tranny, 1058 suncoast
45% injectors
Double batmo s472
Dual pumps
11.80 @ 114mph
lmmduramax is offline
post #3 of 19 (permalink) Old 01-03-2012, 09:58 PM
wildbill's Avatar
check your heater hoses that come out of the cab on the passenger side. The hardline could have a crack
2002 Sierra SLT CCSB
green keys and blocks
EFI Live and dsp5
Suncoast stage 4 trans
Suncoast torque conveter
Silverline 4" turbo back exh.
17" Ultra wheels riding on 33" duratrax
FASS fuel platinum series 95gph
Interior: all led lights
ext: HIDs, LED tails and bumper lights
wildbill is offline
post #4 of 19 (permalink) Old 01-03-2012, 10:06 PM Thread Starter
Well I am glad the first two responses did not mention head gasket haha
I did pop the hood and looked like it could have possibly came from the surge tank but I am not sure at all, too dark
Thanks for any more suggestions
post #5 of 19 (permalink) Old 01-04-2012, 09:19 AM Thread Starter
Had co2 test done on coolant and it did not change color indicating a HG leak... everything I read online is always the horror story of blown head gasket.
This morning truck was showing it was running cold and the surge tank was pushing out coolant than it seemed that something opened and the truck temp read normal, the heater blew hot and the low coolant light came on. Because of the loss of coolant before it opened. t-stat issue?
Any suggestions...
post #6 of 19 (permalink) Old 01-04-2012, 09:30 AM
Boomer51's Avatar
You know what it is. Head gaskets, unfortunately. Fill your coolant tank to the brim and let it idle with the coolant cap off. Initially, it will push some water out as the fluid expands, and probably as exhaust enters your cooling system. After a minute or two, I would get bubbles the size of nickles coming to the top of the coolant tank every 15 seconds of so. Hope it's not, but exact same symptoms as I had.
Upper radiator hose hard in the morning?
Boomer51 is offline
post #7 of 19 (permalink) Old 01-04-2012, 03:27 PM Thread Starter
Ya I am keeping my fingers crossed that its not a head gasket.
I changed the coolant tank cap and seems to not be pucshing coolant out since I changed it? Could it have been a pressure relief issue?
$7 fix is a little better than a $4000 fix
post #8 of 19 (permalink) Old 01-04-2012, 03:52 PM
Boomer51's Avatar
Possibly. If your cap was bad. I tried that too. Mine was building pressure and pushing coolant out. It started very occasionally and got progressively worse over a 6-7 month period. It never overheated. Good luck!
Boomer51 is offline
post #9 of 19 (permalink) Old 01-04-2012, 05:05 PM Thread Starter
If I get the cylinders pressure tested, it will determine the verdict 100% correct?
My next step will be t-stats... Because it had heating issues before I put the new cap on...
I will be getting the heads tested if it happens again.
Any more stories or suggestions, would be appreciated
Thanks
post #10 of 19 (permalink) Old 01-04-2012, 05:41 PM
Freakk's Avatar
After you drive it, let it sit overnight and squeeze the upper radiator hose. It should be pretty easy to squeeze. If it's hard then it usually means its a head gasket.
--05 2500 LLY, Victory Red, CCSB, 11" CST Lift, 3" Lift Spindle, 40" Toyo Open Countrys, AMP Steps, ARP Head Studs, EFI Live, Diamond Eye DP, 5" MBRP Exhaust, LBZ Turbo, LBZ MP, PCV Re-Route, Profab EGR Delete
Freakk is offline
