ice pick Fix maybe? - Chevy and GMC Duramax Diesel Forum
post #1 of 28 (permalink) Old 01-19-2012, 04:33 PM Thread Starter
JD32's Avatar
ice pick Fix maybe?
i know there is prob a ton of other threads over the same thing but i searched around and i hope that the 'ice pick fix' is all i need. i noticed today my truck was missing and my insight was saying one of my injectors was bouncing between +10-13... i think its injector #7. i remember checking during the summer, maybe 4k miles ago and they all looked good, so it happened fast if the injector really is bad. i only got 105k miles and she's always ran good... I have a few other questionable injectors tho... attached pic of my balance rates
2005 LT CCSB 4x4 LLY
5" MBRP Straight Pipe with MBRP Down Pipe, EFI Live by Kory Willis, Edge CTS, aFe mouthpiece. Leveled on 34's and 20's
JD32 is offline
post #2 of 28 (permalink) Old 01-19-2012, 04:37 PM
ALLY Cat's Avatar
I would try the ice pick on #7 first, doesn;t cost anything to try it, also check your FICM harness where it is zip tied to the alternator bracket.
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, trans by Mike L, Magnaflow DP, Ride Rites, LBZ turbo inlet mod, AD II 165, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is online now
post #3 of 28 (permalink) Old 01-19-2012, 04:42 PM Thread Starter
JD32's Avatar
alright, ill give that a try, problem is finding time haha
JD32 is offline
post #4 of 28 (permalink) Old 01-19-2012, 05:46 PM
FICM harness fix and ice pick all the injectors for sure, then run 32oz Diesel Kleen in a full tank and check again.
Post up your balance rates again after that and we can help from there.
MTL_Dmax is offline
post #5 of 28 (permalink) Old 01-19-2012, 07:19 PM Thread Starter
JD32's Avatar
ok will do. I'll try and get to it ASAP, can anyone point me to any info on the ice pick and harness fix? thanks
JD32 is offline
post #6 of 28 (permalink) Old 01-20-2012, 12:13 PM Thread Starter
JD32's Avatar
can i do this to all my injectors or just 2 and 7? cause 1 is giving me the most problems... and when i checked today it was back to down like +6 hmmm...
JD32 is offline
post #7 of 28 (permalink) Old 01-20-2012, 12:37 PM
Do all your injector connections and use a little dielectric grease on them before reattaching again.
MTL_Dmax is offline
post #8 of 28 (permalink) Old 01-20-2012, 12:42 PM Thread Starter
JD32's Avatar
dumb question but where can i get a ice pick? haha the hardware store?
JD32 is offline
post #9 of 28 (permalink) Old 01-20-2012, 01:13 PM
nick1camper's Avatar
I think a scratch awl will work as well.
2005 ext cab sb LLY
4" exhaust w/muffler, EGR delete/Sinister diesel, Kodiak LBZ mouthpiece, PCV rerouted, Nicktane/CAT adapter, Autometer pyro & boost gauges, EFI Live by Kory, Transgo, pump rub kit, LBZ intake conv, H2's, Debadged
nick1camper is offline
post #10 of 28 (permalink) Old 01-20-2012, 01:15 PM
You don't litterally need an ice pick, just a small set of picks from the hardware store.
Something like this:
http://www.amazon.com/gp/product/B002KHNCSS
MTL_Dmax is offline
