04 c5500 6.6lly no start - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 03-02-2012, 10:08 AM Thread Starter
Hi we have an 04 c5500 6.6 lly with a no start. Cust. brought in with hard starting, he tried to change glow plugs and broke some. We R+R engine and drilled out. Reinstalled engine to a no start. Found broken wire on pcm connector. Repaired and got running. Road test produces code p1093. Shut engine off and won't restart. Replaced fuel pump due to lack of pressure. Also replaced regulator and check valve in lr fuel rail. Ran yesterday and today won't start. Not enough fuel
pressure.
erlesauto1 is offline
post #2 of 6 (permalink) Old 03-02-2012, 10:45 AM
Firefighter08's Avatar
Im sure you replaced the fuel filter. Sounds like its de fueling. Shim kit maybe?
Jacob
2008 SLE GMC C/C.
4" mbrp, FTE resonator, EFI from duramaxtuner, blocked and rerouted.
Firefighter08 is offline
post #3 of 6 (permalink) Old 03-02-2012, 10:49 AM
Originally Posted by Firefighter08 View Post
Im sure you replaced the fuel filter. Sounds like its de fueling for some reason. Bad replacement valve maybe?
Edit
Jacob
2008 SLE GMC C/C.
post #4 of 6 (permalink) Old 03-02-2012, 02:49 PM Thread Starter
Tried shimming relief valve didn't help. However I checked for suction while cranking, first at the back of the engine, nothing. next at the filter inlet then outlet still nothing. Next at ficm still nothing, finally at port at pump and still nothing, have to assume either gear is slipping or pump is faulty. Also tried to start before this with reg on pump electrically disconnected.
post #5 of 6 (permalink) Old 03-07-2012, 09:12 AM Thread Starter
cust got another cp3 pump and still not enough pressure
post #6 of 6 (permalink) Old 03-07-2012, 11:04 AM
Bransjeep's Avatar
Filter housing.. Or maybe a slight leak from the pressure sensor
Black 04 LLY 6" Tuff Country EZ Ride. 35-12.50 20 Trail Graps, Moto Metal 955, Bilstein 5100's. AMP powerstep. 4" MBRP Turbo Back w/5" tip. pcv re-route, LBZ inlet and S&B, EFI Live! DSP5 powered by Edge insight CTS...EGR blocked. Viper remote start and alarm. Custom built bumper by CountryBoy2500, with 3000k HID's and Hella 500's. 5000k HID's in lows. Raptor lined rocker panels. Tinted to match and tow mirrors. Energy Suspension Poly bushings. Kenwood ddx371, 9 speaker J&L audio setup. LML manifold. Air Lift bags, 35 Gallon TransferFlow Tool box combo.
Bransjeep is offline
