Fuel Pressure Relief Valve Removal questions - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 03-10-2012, 02:27 PM Thread Starter
rmdiesel91's Avatar
I recently bought a shim kit for my fuel pressure relief valve. Truck is an 04 lly. The instructions from PPE show a way different glow plug controller than what I have and I can't seem to find any other directions showing how to remove the bracket to actually get to the valve. Anyone else have this issue? How do you get a wrench to the 2 bolts under the bracket?
04.5 GMC 2500 4x4 LLY 5 in exhaust, Diamond Eye DP, LBZ intake, EFI Live, Autometer guages, tie rod sleeves, more goodies on the way!
rmdiesel91 is offline
post #2 of 7 (permalink) Old 03-10-2012, 02:39 PM
DMAXPOWER05's Avatar
I used a stubby 12 mm ratcheting wrench to get to mine.
2005 CCSB LLY 4X4
Tuned by Danville Performance
DMAXPOWER05 is offline
post #3 of 7 (permalink) Old 03-10-2012, 03:10 PM
JMootz's Avatar
just tried to do mine yesterday had to cut a 12mm wrench in half thats all i had butt cant get the valve out
04.5 ccls sb LLY 4" MBRP exhaust from turboback AFE Bladerunner mouth piece, edge insight CTS monitor, ddm HID hi/lo de down pipe egr delete pcv reroute bills custom stage 3 intake,tow mirrors,billet fuel door,tie rod sleves. BD exhaust manifold .dsp5 buit tranny tune from duramaxtunner thanks to Nick&Bob1-815-861-5807[/COLOR].built tranny g max pac 5 thanks SHANE!air dog 165.B D intercooler Afe in and out pipes
JMootz is offline
post #4 of 7 (permalink) Old 03-10-2012, 09:18 PM
A stubby wrench will get the GP bracket off, but those 2 bolts are a major PITA to get to.
MTL_Dmax is offline
post #5 of 7 (permalink) Old 03-10-2012, 11:21 PM Thread Starter
rmdiesel91's Avatar
Truck is all back together. Doing the actual shim part is a breeze compared to the fight of getting those two bolts out. Ended up using an offset short wrench. Thanks for all the feedback!
post #6 of 7 (permalink) Old 02-14-2013, 10:51 AM
Do you have to bleed off the fuel system before removing the valve or will it bleed off as you loosen the valve?
Cseaton is offline
post #7 of 7 (permalink) Old 02-14-2013, 10:55 AM
As long as it has been sitting an hour or two, there shouldn't be any pressure behind it at all.
MTL_Dmax is offline
