Ignition Stuck On... won't turn off..... - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 03-16-2012, 04:15 AM Thread Starter
ksstang's Avatar
Hey guys... On my way to work this morning I noticed my truck was acting funny. The windshield wipers/sterero were dead to the world. My first immediate thought was... a fuse. Well... upon getting to work and backing in my spot... I looked down and noticed my ABS light was on solid, and the brake light next to it was flashing on and off. Now the screwed up part.....
I went to turn the truck off and the ignition is stuck in the run position. It WILL NOT turn backwards to shut off. I'm afraid if I turn too hard that it'll snap the key plumb off. I disconnected the batteries and got the truck to shut off.
But..... what the heck do I do now???
2004.5 Chevy Duramax
ksstang is offline
post #2 of 6 (permalink) Old 03-16-2012, 05:20 AM
Slave to the Interwebs
Johnasara's Avatar
I would mess with the steering wheel. Move it back and forth while trying to turn the ignition off. Or see if you have any play in the column up and down as well. It sounds like it is new ignition time though
Johnasara is offline
post #3 of 6 (permalink) Old 03-16-2012, 05:37 AM Thread Starter
ksstang's Avatar
I've tried the whole steering wheel, gear shift lever, everything. I can't get that key to move for the life of me! I'm hoping its just the lock cylinder thats giving fits. Now if I can only figure out how to get the cylinder out!
ksstang is offline
post #4 of 6 (permalink) Old 03-16-2012, 06:52 AM
Administrator
jc1843's Avatar
The problem might be the switch-- the cylinder does not have anything to do with the ignition part. Pull the lower cover from the steering column. The ignition switch is right there--it is held in with a couple plastic tabs-- just pull it down. Then see if you can turn the cylinder.
The key cylinder turns a gear, and that turns a gear in the switch-- to turn ignition and starter on--or off.
The switch has a detent in the on position, so turn ther cylinder to "ON" when you insert the switch back in. That way it will be indexed correctly.
jc1843 is online now
post #5 of 6 (permalink) Old 03-16-2012, 08:18 AM Thread Starter
ksstang's Avatar
Well, an update. I pulled the switch down out and key would not rotate. I rotated through the selections of the switch with my finger and it seemed to be fine. I connected the battery and even started the truck with my finger on the switch. The key/cylinder still would not turn with the switch down out. I put it all back together and it turned fine a couple times, and then locked in the "on" position again. With the cylinder pulled out of the assembly, I am able to stick a screwdriver back in where the cylinder bottoms out and that portion of everything turns freely too. Uggghhh!!! So aggravating when you NEED your truck tonight and your stuck at work!
ksstang is offline
post #6 of 6 (permalink) Old 03-16-2012, 11:16 AM Thread Starter
ksstang's Avatar
It ended up being the Key Cylinder. Threw a new one in it and its good to go! The little springs that hold the tumblers down for the key were all screwed up, and once it got turned into the "on" position, it was releasing too far and wouldnt turn back.
ksstang is offline
