no crank no start. ANY ADVICE !? - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 04-13-2012, 10:34 PM Thread Starter
battlegraduate09's Avatar
Exclamation no crank no start. ANY ADVICE !?
Been having electrical problems since last July, i changed the bcm today, had it programmed with the tech 2, then tried to re learn the theft deterrant system and it wont with a tech2, tried manual relearn, it locks the truck up after the first cycle out of three. Swapping out ecm tomorrow to see if i can even get the truck to crank.
v2 or tech 2 wil communicate now.
Any body help or have any suggestions??
I know the duramax community is usually pretty tight, but its like when i ask for help on this topic i might as well have chugged a fifth of jack at an AA meeting.
hopefully somebody can help.
Josh
2006 CCSB 4x4 ZF6
battlegraduate09 is offline
post #2 of 12 (permalink) Old 04-13-2012, 10:50 PM
racerx004's Avatar
I don't know if this would even cause this much problems, but have you checked the wire loom that is zip tied to the altenator bracket. I know if it rubbs through and those wires break or ground out, it can cause some strange problems.
2004.5 Chevy 2500HD CrewCab LLY 226,XXX, EFI Live tuned by "Idaho Rob"
LBZ Mouth Piece
Pro-Comp X-Treme 1089 Wheels, Pro-Comp X-Treme A/T 305/65/17
Sonar Angel Eyes Lights and Signals
LED Cab Lights
Side Outlet Exhaust
Peripheral I-Pod Adapter
racerx004 is offline
post #3 of 12 (permalink) Old 04-13-2012, 10:52 PM Thread Starter
iv had electrical issues since last July, i have been through wires and grounds 100s of times.
Josh
2006 CCSB 4x4 ZF6
post #4 of 12 (permalink) Old 04-14-2012, 06:57 AM Thread Starter
Bump
Josh
2006 CCSB 4x4 ZF6
post #5 of 12 (permalink) Old 04-14-2012, 07:21 AM
Hi, I'm Earth. Have we met?
05_LLY's Avatar
Is it actually in Theft lock mode? Any codes present?
Hot rodding duramax trucks since 2004
05_LLY is offline
post #6 of 12 (permalink) Old 04-14-2012, 09:37 AM
Administrator
jc1843's Avatar
Sometimes they get a short under the hood fuse box. The wires rub against the support brackets.
Of course the NSBU switch can always be a problem with the LLY. But without communication-- that cannot be the issue.
Some do have ignition switch problems-- but easy to check with a test light or volt meter.
Good luck
jc1843 is offline
post #7 of 12 (permalink) Old 04-14-2012, 09:43 AM Thread Starter
Can't read codes, won't communicate. Swapping ECMs now to see if it cranks at all
Josh
2006 CCSB 4x4 ZF6
post #8 of 12 (permalink) Old 04-14-2012, 12:07 PM Thread Starter
Bump
Josh
2006 CCSB 4x4 ZF6
post #9 of 12 (permalink) Old 04-14-2012, 02:03 PM Thread Starter
Got it cranking.
Big thanks to George Alexander and bob Olson !!!
Josh
2006 CCSB 4x4 ZF6
post #10 of 12 (permalink) Old 04-14-2012, 02:32 PM
beanpole209's Avatar
What was wrong?
beanpole209 is offline
