Injectors Balance Rates - WHat is bad? - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 05-10-2012, 11:08 AM Thread Starter
2005 DMAX
So; the diesel mechanic says my "balence rates are all over". Replace them all. Loosely they are:
+17 on 1..
a few around +2 ...-2
A few -10
What is the tolerance for injectors? Don't really want to drop 3100 on 8 new ones if I dont have too.
Clint
Cbritt is offline
post #2 of 9 (permalink) Old 05-10-2012, 11:30 AM
usafduramax's Avatar
Bud i really really hope your mechanic doesn't know how to read balance rates, if you have one at +17 and "a few" at -10, I would consider parking the truck until something can be done those are way off...tolerance in park- +/-4.00 in drive +/- 6.00 buy them and do them yourself
usafduramax is offline
post #3 of 9 (permalink) Old 05-13-2012, 12:16 AM
Bransjeep's Avatar
My truck did that with crazy balance rates. I did the ice pick fix on all 8 and they went back to spec. However i had to replace one. Its easy on the lly
Black 04 LLY 6" Tuff Country EZ Ride. 35-12.50 20 Trail Graps, Moto Metal 955, Bilstein 5100's. AMP powerstep. 4" MBRP Turbo Back w/5" tip. pcv re-route, LBZ inlet and S&B, EFI Live! DSP5 powered by Edge insight CTS...EGR blocked. Viper remote start and alarm. Custom built bumper by CountryBoy2500, with 3000k HID's and Hella 500's. 5000k HID's in lows. Raptor lined rocker panels. Tinted to match and tow mirrors. Energy Suspension Poly bushings. Kenwood ddx371, 9 speaker J&L audio setup. LML manifold. Air Lift bags, 35 Gallon TransferFlow Tool box combo.
Bransjeep is offline
post #4 of 9 (permalink) Old 05-13-2012, 12:28 AM
^^^very true, lly is easier
post #5 of 9 (permalink) Old 05-13-2012, 05:52 AM
Banned
Icepick them all.....
Do the FICM harness repair......
Then reread the balance rates and replace the injector the farthest out. One bad injector will throw all 8 off bc they are trying to balance out the knock created by the bad injector, rarely will you ever have to replace all of them on anything but an lb7 and they just do it bc it is such a PITA...........
That mechanic needs some more education on common rail diesels, you were about to get hosed for 6 or 7 injectors you most likely do not need to replace.........
smokinlmm is offline
post #6 of 9 (permalink) Old 05-13-2012, 12:59 PM
X2
Icepick all the injector connectors, reinsulate the the FICM harness at the alternator bracket and do the DIY injector cleaning. After that, start by replacing the injector that is the worst, then check balance rates again. Ideally you would first run a compression test on any cylinders with high positive balance rates. The balance rates are relative to each other so if you have a clogged injector or a cylinder with low compression, it will be a high positive rate (ie engine is adding fuel to that cylinder) while the others will typically have negative rates (ie engine is pulling back fuel from those cylinders). So if you make changes or swap out injectors, it is very important to rechack your balance rates again.
MTL_Dmax is offline
post #7 of 9 (permalink) Old 05-14-2012, 08:42 PM Thread Starter
Thank you. Yes, the mechanic told me all 8 where bad.. You guys are awesome. I have the truck towed home. (125 bucks) paid the mechanic for 3 hours. 300. COmpression check - all 8 are good.
Yesterday - Put the old injectors back in, and now the truck doesn't even start.
Should I buy an EFI LIVE now? Tired of mechanics that don't know what they are doing on the LLY. Truck is sick. Could be electric Could be injectors.
Cbritt is offline
post #8 of 9 (permalink) Old 05-15-2012, 06:04 AM
Banned
Can't hurt...... At least you can do the diagnostics yourself.....
If you aren't building at least 3000 psi of rail pressure the truck is hard to start. You need to check to see how much fuel is returning to the tank also by doing a bottle test of the FPRV when it leaks the rail can not build proper pressure to atomize the fuel when the injectors fire resulting in a no start condition.......
I think you may have a couple problems that are compounding into one.........l
post #9 of 9 (permalink) Old 05-16-2012, 05:08 PM
duratothemax's Avatar
no, try 1500psi.
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
