LLY mpg? - Chevy and GMC Duramax Diesel Forum
post #1 of 52 (permalink) Old 07-03-2012, 04:21 PM Thread Starter
Angry LLY mpg?
Just got back from a 1st time, 1000 mile camping trip in my lly and expected better mpg when comparing it to my lmm. Had a pickup box camper, small boat, and gear I estimate at around 5200 lbs. Seen 11.3 mpg on the way there, and 12.2 on the way home. Iíve ran this exact same trip (several times in the past) with my lmm with 5th wheel, larger boat, more gear I estimate at 9800 lbs. and never seen anything under 10.8 mpg to 11.6. Both trucks run 50 hp efi live tow tunes. Iíd run the lmm in manual 5th gear, th on, and the lly in 5th gear and th on. Same speed 60-63 mph. I guess being 4000+ lbs lighter I was expecting 13-14mpg. Is this just an lly thing? Or should I be looking into something? In my mind it just donít add up. I over maintenance everything so I donít know where to start. I feel a 6.0 gas would have pulled them #ís. I should add, I see good #ís when empty. 19-20.5 at 60mph.
09 Silverado K3500 LT CC SRW, 4" MBRP TB muffler only, EFI Live 50hp tow tune, EGR Block, stock tires.
04 LLY Silverado K2500 LS Reg cab, 4" straight MBRP TB, EFI Live DSP2 50 hp tow tune, econ tune, EGR Block, AFE mp, tires upped to 265/75 r16.
BGD-09DM is offline
post #2 of 52 (permalink) Old 07-03-2012, 04:24 PM
primetime_2's Avatar
were you fightin the wind at all?
-2012 DENALI 1500
-2006 GMC CCSB LBZ --Sold--
-2004 Grand Prix GTP
Stocker
-2008 Pearl White Streetglide
primetime_2 is offline
post #3 of 52 (permalink) Old 07-03-2012, 04:59 PM Thread Starter
Not alot. Way up was just about nothing. Way home had maybe 10-15 out of the west but 80% of the trip runs north to south.
BGD-09DM is offline
post #4 of 52 (permalink) Old 07-05-2012, 12:56 PM
15 litres per 100KM in town
12 on the highway
around 20mpg
LLY- is offline
post #5 of 52 (permalink) Old 07-05-2012, 01:15 PM
rd05lly's Avatar
What are the tire pressures? I have never got the bad of fuel mileage in my lly 14 is as low as I get towing.
05 CCSB EFI Live by PPEI
2011 Chevy Tahoe
04 Olds Alero DD
76 Dodge Charger SE
https://www.syntheticmotorsports.com
rd05lly is offline
post #6 of 52 (permalink) Old 07-05-2012, 01:38 PM
Administrator
jc1843's Avatar
How fast were you driving-- speed affect the MPG a lot!
Did you hand caculate the numbers? Or use the DIC-?
jc1843 is offline
post #7 of 52 (permalink) Old 07-05-2012, 06:17 PM Thread Starter
And with only 5000 lbs that is what I was expecting. I had them maxed out at 80 psi. Can I ask how much weight do you tow? Speed? Thanks
I donít care to give our state law enforcement any money so I never go over 62-63 mph. But at that speed it is running around 1900 rpm. Is that rpm starting to kill mpg? I need to run the lmm down the road again, but I think in manual and 5th gear, Iím running the same rpm. All figures were hand calculated.
This might be worth mentioning. Iím no expert on aerodynamics but the front of the camper is completely flat. ( bunks above the cab) Which measures 7í x 3í. Could I be loosing 2-3 mpg over that?
BGD-09DM is offline
post #8 of 52 (permalink) Old 07-05-2012, 07:08 PM
I average 15.5-16.0 mpg combined (in town/limited highway), 20-22 mpg highway (avg. 65 mph/empty), but it quickly drops to 9-10 mpg when towing my 36' WW (60-65 mph/14K-15K trailer weight). With what you were towing, I'd expect to get 13-15 mpg easy, but towing mileage seems to be a strange beast. I've read some threads where owners claim roughly the same mileage regardless of what they're towing...
2005 CCSB LLY
AFE mouthpiece
Airbox mod
MBRP 4" cat back
Firestone airbags
Curt R16 5th wheel
CTS Insight
olddudesrule is offline
post #9 of 52 (permalink) Old 07-05-2012, 08:00 PM
DMaxxrus's Avatar
Do the lbz mp and egr delete. You will see 2 mpg right there...well atleast i did.
DMaxxrus is offline
post #10 of 52 (permalink) Old 07-05-2012, 09:08 PM
3521 USMC
chevylovinfordtech's Avatar
his sig. already says hes got a delete, but x2 on the mouth piece, and if u havent already done it lose the kitty!!!
-Robert-
2005 CCSB Silverado 2500 HD LLY
Performance: LBZ Mac performance intake, LBZ mouthpiece, MBRP duals, shim kit, ported fuel rail fittings, headstuds, FASS150, FASS fuel filter delete bowl, LBZ FPR, EFI live by Idaho Rob
Air Flow:finger vanes, ported turbine housing, BatMoWheel, losend unison ring, ported exhaust manifolds, gasket matched up-pipes
Exterior: Rear Reunel bumper, leveled tow mirrors, HIDs (all on mod), ADP tie-rod sleeves, green tinted headlamp housings
Interior: 2 12" memphis car audio subs, custom sealed box and 2000 watt memphis amp, LED interior, dash and door lights-green, cobalt autometer pyro and boost piller gauges
Best Time: 13.92 @ 95 mph 1.96 60 foot
Work In Progress: 1969 Chevy Nova, built turbo 350, 283ci small block est. 550hp with 7500 rpm redline, caltracs, 4.11 ford 9" rear end, dual 3"exhaust
chevylovinfordtech is offline
