white smoke, low power - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 08-18-2012, 07:14 PM Thread Starter
dirty_maxx's Avatar
hey guys, so ive noticed lately that my truck is smoking more white/grey than nice and black like it used to, and its a little low on power. i just did the gm injector cleaning on it and my balance rates are at idle:
1: -.8
2: -.4
3: -.8
4: .6
5: 1.5
6: .6
7: .5
8: -1.6
fuel rate is 14.0 with a/c on and 7.5 without a/c and my rail pressure seems to be all over, 1000 psi more actual than commanded at times, and lower than commanded at other times. im certain that my fpr is bad cuz it loped really bad before i put my airdog on and it was loping really bad when i was doing the injector cleaning. my fuel pressure is set at 12 psi and at wot it drops to about 8 psi. any ideas on what could be wrong would be much appreciated.
2004 chevy 2500hd eclb, lly, 6spd manual, lift, rims and tires, afe intake, mouth piece and intercooler pipes. mbrp downpipe, mbrp 4" exhaust, pcv reroute, airdog 2 165, nicktane cat filter adapter, cognito and kryptonite front end, autometer cobalt gauges, valair dual disc clutch, fluidampr, efi live
dirty_maxx is offline
post #2 of 5 (permalink) Old 08-19-2012, 04:32 AM
1: -.8
2: -.4
3: -.8
4: .6
5: 1.5
6: .6
7: .5
8: -1.6
That FPR is shot, change it out first and then see if you still have issues.
MTL_Dmax is offline
post #3 of 5 (permalink) Old 08-19-2012, 04:39 AM
Hang it!...Fire!
TDIpowered's Avatar
also try the fprv. might need to shim or plug
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
post #4 of 5 (permalink) Old 08-19-2012, 04:41 AM
Agreed, change the FPR first, then bottle test the FPRV right after.
MTL_Dmax is offline
post #5 of 5 (permalink) Old 08-19-2012, 11:15 AM Thread Starter
dirty_maxx's Avatar
sorry i forgot to put in my signature that my rail is plugged. ill try the fpr and see where it goes from there. thanks guys
