Broke the magnet inside the transfer case - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 10-30-2012, 02:07 PM Thread Starter
e46_330i's Avatar
Don't ask me how.... Lol Finally had enough time to finish to put my transfer case back together after the pump rub job and I broke the magnet in 3 pieces. I can't seem to find a replacement so my only option seems to be to leave it out & get a magnetic drain plug. Will that suffice? Should I put a similar sized washer in there to fill the hole? What are my options here?
Thanks!
LLY CCSB SLT 4x4
*EFI DSP5 By: PPEI *DE Downpipe & 5" Dump *ARP Studded *Pro-Fab Deleted *Custom Re-Routed *Alligator FPRV Plugged *DHD Braced & MA Sleeved *20x12 -44's *305/55/20 Terra Graps *LBZ MP, Intake & FPR *Kleinn Horns & On-Board Air *Paramount Restyling Grill hiding a 30" LunatecLED light bar *MA Pump Rub & M1 5w-30 *All-On Mod *PPE Boost & Pyro *Edge CTS W/Reverse Cam
Willie @ Synthetic Motorsports
Kory @ PPEI
Eric @ Merchant Automotive
Jason @ Alligator Performance
e46_330i is offline
post #2 of 15 (permalink) Old 10-30-2012, 02:43 PM
ALLY Cat's Avatar
Are you talking about the magnet on the spin on filter? Half the time dealers lose them when they service your truck. Won't hurt it to drive a little while without it. Get a magnet at your local dealer or from one of the vendors on this forum. You can spin the filter off and replace it any time, you shouldn't lose any fluid-or at least not enough to matter-if you do it carefully. Or just replace the filter with a new magnet in a couple thousand miles.
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, trans by Mike L, Magnaflow DP, Ride Rites, LBZ turbo inlet mod, AD II 165, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is online now
post #3 of 15 (permalink) Old 10-30-2012, 03:15 PM Thread Starter
e46_330i's Avatar
Transfer case not transmission.
LLY CCSB SLT 4x4
Kory @ PPEI
e46_330i is offline
post #4 of 15 (permalink) Old 10-31-2012, 05:40 AM Thread Starter
e46_330i's Avatar
Anyone? Probably going to use a thin piece of sheet metal cut to shape and epoxy the pieces together on it, using the metal as a backing plate. Hopefully it works out like that at least.
LLY CCSB SLT 4x4
Kory @ PPEI
e46_330i is offline
post #5 of 15 (permalink) Old 10-31-2012, 06:47 AM
it stinks and whistles :)
Brennan's Avatar
Is there a hole in the case?
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #6 of 15 (permalink) Old 10-31-2012, 06:59 AM Thread Starter
e46_330i's Avatar
There was but what does that have to do with the magnet?
LLY CCSB SLT 4x4
Kory @ PPEI
e46_330i is offline
post #7 of 15 (permalink) Old 10-31-2012, 07:06 AM
SST 1953's Avatar
He is referring to the rectangular magnet in the slot with the pump pickup inside the transfer case. You can probably find something similar at a craft store. The drain plug with the magnetic tip would work also
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline
post #8 of 15 (permalink) Old 10-31-2012, 07:27 AM Thread Starter
e46_330i's Avatar
It's actually round, but I am going to try to fix it today.
LLY CCSB SLT 4x4
Kory @ PPEI
e46_330i is offline
post #9 of 15 (permalink) Old 10-31-2012, 09:03 AM
Brennan's Avatar
Maybe it was my lack of coffee, but I was thinking you wer trying to fix a hole in the case with some epoxy and a piece of metal. Ignore my last post :
06 lly,
air dogII 165
Brennan is offline
post #10 of 15 (permalink) Old 10-31-2012, 09:06 AM
Trevor's Avatar
why wouldnt you go to a wrecking yard to find one or the stealership. i wouldnt trust the epoxy if it was mine. just my .02
08 lmm cc/sb
built trans atp efi
Trevor is offline
