| Junior Member Join Date: Oct 2011 Location: Lake Orion, MI
| 05 lly no start just did head gaskets Just got everything back together truck will start with propane but not on its own codes that come up are P1094 fuel rail low wheel idle or fuel cut and P0087 FRP too low , the rail pressure desired is around 30 but its only making 15 just wondering where I should start to get it running right, did a fuel filter head rebuild while out shimed the fprv checked that and it is still in tact ,there is no fuel in the oil ether, don't know if its air in the system or what but let me know what everyone thinks, been waiting too long for her not to run.. any questions or comments further I will have my phone on me..thanks in advance everyone!
__________________ -Brad -05 LLY White CCSB -EFI live with dsp5 switch, by Eric at MA. -S&B intake with LBZ mouthpiece. -Glowshift gauges (temporary)egt and boost. -EGR Blocker plate. -Leveled with 285/75/16 BFG Rugged Terrains. -Painted black stock wheels. -ARP head studs, New style headgaskets -Shimmed, Diamond Eye Downpipe -The rest of my Exhaust and a Trans this summer.. |
| Anyone? Sent While taking a Cruise
| On the back of the fuel rail- pull the hose from the fuel rail nipple and plug the hose-! Now crank the engine and if ANY fuel at all comes from the rail nipple-- the FPRV that you shimed is leaking fuel, and lowering the rail pressure.
| Alright thanks trying now! Sent While taking a Cruise
| Moving to LLY-- truck in shop.
| | eBay Motors #6 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
First what units is that fuel pressure in? kpsi? Mpa? other? Few things to check: 1) Make sure your FPR is plugged in 2) Make sure your rail pressure sensor is plugged in 3) Check your return hose off the FPRV to be sure it's holding (bottle test)
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
| FPRV was not holding replaced and truck is up and running! Sorry for the wait been hectic around here, everything is all set though and just coated the frame after a good cleaning and i'm just bout ready for winter! I wanna say the Modis default is MPA for rail pressure, Thanks for the help guys!
