| | eBay Motors #11 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
Could be either case but in order to keep EGTs down you need to get as much air in there as possible (ie boost pressure) and the EGR is working against you in that respect if it blows open or leaks.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
| | eBay Motors #12 (permalink) | |
| Quote:
Joe, can't wait to see what you come up with for addressing both oil and coolant solutions.
| | eBay Motors #13 (permalink) |
| DuramaxForum n00b Join Date: Jun 2012 Location: Indiana farm country
| I added aem intake , afe blade runner turbo mp and 4 inch mbrp exhaust and down pipe and noooooo problems. (knocking on coffee table ) |
| Junior Member Join Date: Jan 2009
| From what I am reading, leaking seems to be more of a problem than being forced open. I might as well remove mine and see how it looks after 91k.
__________________ 2005 Chevy Silverado 3500LT SRW D/A CC/LB LLY 4x4 (loaded) LBZ MP, TxCAI, PS Cooler, stack seal, Edge Insight CTS, E837 Aux Radiator w/fan, Renodmax/Earl's Trans Cooler, Mass/IAT Shield, Fuel Cooler Fan, LML manifold NuWa Hitchhiker II LS 29.5LKTG 5th Wheel |
| | eBay Motors #15 (permalink) | |
| Junior Member Join Date: Aug 2012 Location: Arizona
| Quote:
The best thing you can do is be diligent about monitoring all fluid temps and make adjustments as necessary. Don't waste money on fixes you don't need. Use that money to take the Mrs. out once in a while so she'll let you buy the "fixes" you want.
__________________ 2005 Duramax LLY LS trim 4x4 Mods: Secondary Cooling System with fan and shroud, KD custom ECM, EGR blocker, Sun Coast ram air hood, Air Raid intake, AFE turbo MP and downpipe back exhaust, 75Gallon aux tank, Air bags, AVICZ1 DVD NAV, Cobra radar detector., Inverter for my XBOX360, 2" leveling keys with Rancho shocks, 33x12.5x18" toyo tires, Bully Dog stage 1 shift kit, Merchant Automotive pump rub plate. My blinker is not a request, it's a warning. | |
| | eBay Motors #16 (permalink) |
| DuramaxForum n00b | I bought killer bee"s Intake kit. I does help the engine breath better. When I was towing my 14000# toy hauler there was no point in going over 2400 rpm. Engine didnt make any more power just noise. After the installe it would pull hard all the way to redline. I never overheated but the the fan ran all the time. Full lock up on the clutch fan. My intake temps at the MAF would read 160 degreas or higher. Rember the fan takes a lot of power to run. Then I installed Joes radiator on my my GMC. Now when pulling my 14000# parachute (LOL) the fan rarely runs. When it engages it is only for a minute or 2. I am happy I did this mode. |
| | eBay Motors #17 (permalink) |
| the SLEDGEHAMMER Join Date: Sep 2011 Location: upstate nj
| dude all ya need is nos...fog yer radiator instead of yer intercooler
__________________ 04.5 2500hd |
| | eBay Motors #18 (permalink) |
| Junior Member Join Date: Jul 2012 Location: New Orleans, LA
| i really wish someone had more definite proven repair/improvement for the fan clutch noise nightmare. If I wanted to drive 20 hours sounding like a MAC truck, I would have purchased one. The first time it happened it scared the belt loops off my new jeans! I had no clue what had happened. I am now not looking forward to towing ever again, even though this year coming up will be the reason i purchased the truck in the first place... lots of towing my enclosed car hauler.
__________________ 2005 Silverado 2500HD Crew Cab -LBZ mouthpiece |
| | eBay Motors #19 (permalink) |
| Has anyone tried the larger intercooler pipes. Just curious |
| | eBay Motors #20 (permalink) |
| how heavy is the trailer loaded? at the bear minimum you should do the mouthpiece mod, be it the LBZ or the aFe.
