| Junior Member Join Date: Apr 2009
| Grade B to grade C ? Does it matter if we install a grade c head gasket versus the original grade B??? Whats the torque spec for arp head stud? |
| | eBay Motors #2 (permalink) | |
| Junior Member Join Date: Mar 2011 Location: Butler, PA
| Quote:
. The torque sequence is in the box for the studs.
__________________ 05 EC/SB Sierra SLT Rerouted, AFE MP, 5 Inch D.E. Str8 Pipe, pro fab dp, Edge CTS, EFI by Rob, Sleeves, ported fuel rail fitting, ARP headstuds and grade C gaskets, Leveled on black H2's with 285's. Future Plans: Trac Bars, Lift Pump Tyler @ www.meyerperformance.com | |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| Grade c will be fine regardless of what came off originally. Like said above, the torque sequence should be in the box on a piece of paper
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods |
| Senior Member Join Date: Jan 2011 Location: long island new york
| So you don't have to make up the difference of thicknesses by shaving the head ? Sent from my iPhone using AutoGuide.com App
__________________ 2005 RCLB LLY EFI Live/Gmax 5-3/Precision ML/SDP S475 Twin Kit/Lml Manifold/Egr Delete/Arp Studs/Downpipe/Mag Hytec Deep Pan /AirDog 165/Ma Transfer Case Bracket/Ma Pump Rub/Yukon Grizzly Locker/Mag Hytec Deep Diff Pan/Mbrp 6' Black Mitre Cut 477/950 dynojet xdp open house rollers NO TWINS Nitto 285/70/17 NBS rims Autometer/Isspro 13.4 englishtown raceway Limo Tint Recon Cab Lights Smoked Line X,Black Bowtie |
| Duramax Lifetime Supporter ![]() Join Date: Jul 2012 Location: butler, pa
| Grade c covers all
__________________ 2007 Classic lbz Turbo back exhaust, Efi live auto cal from idaho Rob egr blocked, trans go jr, grizzly locker,leveled 285-75-16 wrangler duratracs radials on pro comp wheels,remote start, afe intake air dog 165, billstien 5100s,Afe intercooler pipe, pcv valve reroute, diamond eye down pipe , bushwacker pocket flares, BD exhaust manifold, g2 diff cover with girdle stage 5 trans coming soon. line x bed liner,extang trifold toneau,edge cts, allison deep pan with transynd fluid suncoast filter lock. |
| thanks its done !!! for one side :P |
| DuramaxForum Enthusiast Join Date: Jun 2011 Location: Bellingham, Wa
| not true. It depends how much the heads get machined.
__________________ Gideon ![]() 01 LB7 EC/SB Ally 4x4 shop ornament DD: 1990 4runner completely stock 4x4 3.slow Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel |
| Duramax Forum Supporter Join Date: Nov 2010 Location: Kent, CT
| These heads do not have combustion chambers. So why does milling the head effect the required gasket thickness? Is it because of the valve seat depth from the cylinder head face?
__________________ 2007 GMC Seirra 2500, Reg. Cab Long Bed EFI LIVE , Diamond Eye Duals, Fass lift pump, Transgo JR, Shimmed Relief valve and Ported Fittings18" XD Hoss Wheels, 285-65-18 NITTO Trail Grapplers 2007.5 GMC Seirra 3500HD CCLB DRW SLT stock 1994 4x4 Chevy S10 350 small block fuel injected http://www.dmaxstore.com/ |
| Quote:
__________________ Gideon ![]() 01 LB7 EC/SB Ally 4x4 shop ornament DD: 1990 4runner completely stock 4x4 3.slow Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel | |
| Always in process Join Date: Apr 2010 Location: Western MA
| Head gasket thickness is based off of piston protrusion. If the heads are done properly and the valves set within the factory service limit there is no change in piston to valve clearance.
__________________ 2001 Chevy CC/SB 4x4 Howards Rods,Fingers pistons,Hamilton valve springs,Exergy 100% overs,Custom dual CP3's,Bullseye Billet S475,DTS intercooler,Tuning by Kory Willis |
