lly 2004.5 head gskt replace now no oil press - Chevy and GMC Duramax Diesel Forum
Old 11-17-2012, 12:34 PM   eBay Motors  #1 (permalink)
hi new here have a question i just did the head gaskit" on a2004.5 duramax and now it will start but will not run and it has no oil pressur . i changed the oil after i changed the gaskits so i know it has oil the oil press switch is pluged in. it will run for about 10 to 15 sec but the gage does not register any oil pressure any ideas
stergin fishing is offline   Reply With Quote
Old 11-17-2012, 03:06 PM   eBay Motors  #2 (permalink)
im wondering if i missed a plug some where . it is makeing a beep ing nois somewher by the turbo . any help . if i pump the fuel filter up it will run about 20 sec. then it just runs out of fuel but the oil pressure gauge never moves. so does it have a low oil pressure fuel shut off ?
Old 11-18-2012, 03:53 AM   eBay Motors  #3 (permalink)
Deere1's Avatar
check all your electrical connections
2004 CCSB White,Cowl hood,20% tint,Tahoe white door pulls,White tailgate handle,Pulls a 24ft V nose car trl,or a 29ft travel trailer
Bully Dog Triple Dog w Crazy Larry
4 ich straight exhaust ARPs Mod MP Blocked EGR Raptor 100 Train horns CTS Hidden blue strobes in grille(fire dept) Rapid Hitch
Deere1 is offline   Reply With Quote
Old 11-18-2012, 06:02 AM   eBay Motors  #4 (permalink)
onthefritz's Avatar
You didn't put a headgasket on upside down did you? I think I remember hearing something like this before.
05 EC/SB Sierra SLT
Rerouted, AFE MP, 5 Inch D.E. Str8 Pipe, pro fab dp, Edge CTS, EFI by Rob, Sleeves, ported fuel rail fitting, ARP headstuds and grade C gaskets, Leveled on black H2's with 285's.
Future Plans: Trac Bars, Lift Pump
Tyler @ www.meyerperformance.com
onthefritz is offline   Reply With Quote
Old 11-18-2012, 11:34 AM   eBay Motors  #5 (permalink)
i went really slow, checked the gasket twice and am pretty shur that i got them on the right side and the right end up . but if i got one on wrong souldnt it still build oil pressure ? and does any one know what that beep beep beep noise is . it only comes on when the key is in run . and it sounds like its coming from under the turbo.
Old 11-18-2012, 12:51 PM   eBay Motors  #6 (permalink)
Super Moderator
jc1843's Avatar
The oil pressure connector is under all the wire harness on the driver's side valve cover. I believe it has 3 terminals. If not connected, it will show a fault display.
Old 11-18-2012, 06:55 PM   eBay Motors  #7 (permalink)
thank you . i did not have a code reader but now i have a superchip flash paq it sayes it has a diagnostic trouble code reader so monday will check .
Old 11-18-2012, 06:59 PM   eBay Motors  #8 (permalink)
If you will look on the front of the drivers side head and the rear of the passenger one they will be labeled, just a quick easy way to make sure you didn't "mirror" them on.
[/SIGPIC]07 white ccsb, levelled, XD rockstars w/295-65-18 goodyear duratracs, efi live by Nick Pregnitz,trans tuning by Nick, PPE stg5... built buy yous truly,Goerend converter, ppe manifolds and up pipes, PPE high flow feed line,edge insite, PPE guages, air dog II 165, AFE stg 2/w mouthpiece, factory ff housing delete, PPE rail nozzels on both sides, PPE race valve, MA pump rub kit, SDP egr delete w/ matching hot side ic, PPE brushed deep pan and diff cover, PPE tie rod sleeves,cognito 50" track bars, cognito brace kit, flo-pro 3" down pipe, 6" aussie stacks, front and rear ranch hand replacement legend series bumpers,ddp 75hp injectors, drp fuel sump, limo tint all the way around
LBZMAN is offline   Reply With Quote
Old 11-19-2012, 03:45 AM   eBay Motors  #9 (permalink)
Deere1's Avatar
I have heard a dealership around here that installed HGs backwards. Engine did run for a while.
Old 11-19-2012, 09:23 AM   eBay Motors  #10 (permalink)
pluged in the reader the codes it shows are PO642 and PO193 one says fuel rail pressur high and dont know what the other one is. is ther a code section in this form ?
