Filter head leaking - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 07:52 AM   eBay Motors  #1 (permalink)
Filter head leaking
My truck has been starting for 3 seconds in the morning then shutting off. I traced it to the fuel filter head. Seems like truck is loosing prime overnight. I did the research and ordered the rebuild kit, but in second looks, it appears to be bubbling from the location in the picture. I dont think the rebuild kit addresses this location. What is this sensor and how do I stop it from leaking?
Gunpilot is offline   Reply With Quote
Old 11-19-2012, 09:37 AM   eBay Motors  #2 (permalink)
That's not a sensor, it's your fuel heater.
This video will show you what's included in the rebuild kit:
MTL_Dmax is offline   Reply With Quote
Old 11-19-2012, 09:53 AM   eBay Motors  #3 (permalink)
GM Parts guy
DMAXfirefighter's Avatar
The rebuild kit does come with a new o-ring for that spot, you'll be good once you do the rebuild
ASE Certified and GM Parts guy
MY truck - 2002 2500HD Crew Cab Short Bed
Her truck - 2006 2500HD Crew Cab Short Bed
Traded:2002 2500HD Crew Cab Long Bed
SOLD:2001 2500HD Ext. Cab Long Bed
For spicee tuna go to www.TrollPerformance.com
DMAXfirefighter is offline   Reply With Quote
