Deleted factory fuel filter today and won't run - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 07:43 PM   eBay Motors  #11 (permalink)
Bump. I'm the only one thats had this problem.
2005 LLY CC/SB 4x4/Allison. Air Dog II, EFI live, Built trans, EGR delete.
1994 dodge ram 2500 CTD stock and gutless 4x4 auto reg. cab flatbed.
farmerkirkie is offline   Reply With Quote
Old 11-19-2012, 07:55 PM   eBay Motors  #12 (permalink)
mackyoudip's Avatar
Mine took about 5-10 minutes of my AIRDOG running Til it primed enough to start when I deleted mine.
Mack: LMM.
mackyoudip is offline   Reply With Quote
Old 11-19-2012, 09:33 PM   eBay Motors  #13 (permalink)
I let it run 2 or 3 and just keeps dieing. Only place to get the air out now is the test port. Sure looks like I got all the air out. IDK this CR engine might be more particular than I'm used to.
I will let it run in the morning for longer. Right now I'm pulling the engine out of my brute force while my trucks out of the garage. Fun Fun
Old 11-19-2012, 09:38 PM   eBay Motors  #14 (permalink)
Banned
I would unhook the hose that you just hooked up and have someone in the cab to try and get most of their airout of the system.
Old 11-20-2012, 10:41 AM   eBay Motors  #15 (permalink)
No change let the air dog pump for 15m several times. Well actually its worse, yesterday it would run for a few minutes sputter then die. Now runs for 5sec then dies. I guess I need a pressure gauge for the test port, call pureflow or put the factory filter back on.
Old 11-20-2012, 12:04 PM   eBay Motors  #16 (permalink)
Banned
I know when I had TTS fuel pumps on my LBZ after I deleted the factory fuel filter assembly my truck would not run at all until I put the OEM filter head back on. Personally, I would put it back on as that fixed my issue.
Old 11-20-2012, 12:21 PM   eBay Motors  #17 (permalink)
Alligator Performance
lb7blksmk's Avatar
How does the filter head being in place matter if it starts or not?
Mines been removed for months now. same with every one elses here.
To the OP check your hose routing and make sure it is not kinked when routing back.
www.alligatorperformance.com
03 LB7 EFI
David 208-777-1977
david@alligatorperformance.com
lb7blksmk is offline   Reply With Quote
Old 11-20-2012, 03:25 PM   eBay Motors  #18 (permalink)
Definitely no kink its a perfect radius, people plug off the WIF with no problem, I doubt the fuel heater has anything to do with it. I left a message with Kyle at pureflow, I will try him again tomorrow. Kennedy Diesel has a gauge for the test port for a 150 bucks and with the holiday I'm sure its a week out.
Old 11-20-2012, 03:44 PM   eBay Motors  #19 (permalink)
sounds like you are suckin air in somewhere after the Lift Pump. Checked all your connections SUPER DUPER good ?
NON-DURAMAX OWNER
GM Dealership Employee
ACDELCOduramax is offline   Reply With Quote
Old 11-20-2012, 08:57 PM   eBay Motors  #20 (permalink)
Been running for a year with the Air Dog without a hiccup. Now all I do is undo the two jesus clamps, unbolt the factory filter, add a piece of 1/2 hose and use two worm gear clamps and tighten them with a 5/16 nut driver, the only thing it could be is defective hose. I'm at a loss.
