Deleted factory fuel filter today and won't run - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 04:52 PM   eBay Motors  #1 (permalink)
I changed oil engine today and decided to delete factory filter. Unplugged the two harnesses and pulled the hose off the FICM, grabbed a piece of 1/2" fuel hose and coupled both ends from where the filter was.
Started right up and died. I figured had a bit of air. Let the Air Dog run for a minute or two, started right up then will run for a while misses every few seconds and after a minute or so it will die. Did this multiple times.
I opened up the fuel test port used a pick while lift pump was on and pressed on the schrader valve and got a bubble of air out. Still runs for minute then dies, can't get any more air out of the test port good clean fuel and plenty of it.
What should I try next???????
2005 LLY CC/SB 4x4/Allison. Air Dog II, EFI live, Built trans, EGR delete.
1994 dodge ram 2500 CTD stock and gutless 4x4 auto reg. cab flatbed.
farmerkirkie is offline   Reply With Quote
Old 11-19-2012, 05:06 PM   eBay Motors  #2 (permalink)
6dot6's Avatar
thats wierd man u shouldnt have to worry about air anymore with the ad. hope you get er up and going man.
- 2010 GMC sierra dually SLT CC -
sdp twins,60 overs, efi by rob, trac bars
built trans/ suncoast 1058 converter
djm 3/5, sleeves and braces, 5inch straight pipe
cts insight, ad2 165, 1pc shaft, reroute
airbags, bt lockbox
thanks to: Bigdipper, ATP, BT Dieselworks, Blackout Performance
time to beat: 12.60 @ 108
6dot6 is offline   Reply With Quote
Old 11-19-2012, 05:08 PM   eBay Motors  #3 (permalink)
Is your air dog functioning properly
2006 SILVERADO 2500HD 4WD CREW CAB W/T LBZ MODS: LEVELED, BFG 285/75/16,
streetbrand1 is offline   Reply With Quote
Old 11-19-2012, 05:11 PM   eBay Motors  #4 (permalink)
lddrew's Avatar
subscribing/
did you prime the air dog?
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline   Reply With Quote
Old 11-19-2012, 05:41 PM   eBay Motors  #5 (permalink)
TakeEm's Avatar
Originally Posted by lddrew View Post
subscribing/
You don't have to prime an AD. I would hook up to that schrader valve and make sure all the air is out.
Sent from my Autoguide app.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 11-19-2012, 05:44 PM   eBay Motors  #6 (permalink)
lddrew's Avatar
oh my bad. I have been reading about so many different LP's. Sorry about that
-Lee-
my "build" thread
ATP Trucks
Old 11-19-2012, 06:16 PM   eBay Motors  #7 (permalink)
TakeEm's Avatar
Not a problem! The AD is supposed to filter out the air automatically and send it back to tank, providing the CP3 with fuel only. Notice I said supposed to!
Caleb 22
Old 11-19-2012, 06:20 PM   eBay Motors  #8 (permalink)
lddrew's Avatar
I mean do you not need to prime the AD with fuel on initial install??
-Lee-
my "build" thread
ATP Trucks
Old 11-19-2012, 06:27 PM   eBay Motors  #9 (permalink)
I'm sure there was some air after having both ends open. The Air Dog seems to be working fine and has been on for one year with no other problems until now. I haven't checked with a gauge but at the test port you can push the valve in a full flow of fuel will push out 6"ish inches with no air bubbles.
Old 11-19-2012, 06:29 PM   eBay Motors  #10 (permalink)
TakeEm's Avatar
Nope, I never did. I put mine on, keyed on for maybe 30 seconds and it fired right up. This is with both AD filters dry (new) and a Cat filter on stock filter head dry (new). I wanted to test out the air filtering that AD claims and it for sure did.
Caleb 22
