custom made air scoop - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 07:24 PM   eBay Motors  #1 (permalink)
image-40.jpgAttachment 58761i made this scoop awhile back and just now got around to taking pics of it, i drilled a 3 inch hole in the bottom of my AFE CAI and routed it to the custom made box on the bottom then covered it with black plastic likr the wheel well and you dont even know its there. what you all think?Attachment 58761
Surprise Duramax
Surprise,Arizona
2005 GMC
LLY,6 INCH LIFT,FOX SHOCKS WITH REMOTE RESEVOIRS,REAR AIRBAGS,18 INCH BOYD CODDINGTON RIMS,12.50X35 OPEN COUNTRY TOYO'S,CAT REMOVED,DEBADGE,5" EXHAUST AND MONSTER MUFFLER,AFE MP,DEEP TRANS PAN,EARL'S LARGER TRANS COOLER,LARGE FLUIDYNE OIL COOLER,AFE COLD AIR INTAKE,AFE MP,3 DOWNPIPE,CUSTOM MADE AIR SCOOP,ONBOARD AIR,TRAINHORN.CTS MONITOR,AUTOMETER PYRO GAUGE, DOUBLE LIMO TINT ALL THE WAY AROUND,HELLO'S IN REAR,6K HID HEADLIGHTS,REMOTE ELECTRIC BEDLOCKER,ELECTRIC TAILGATE LOCK.
surprise duramax is offline   Reply With Quote
Old 11-19-2012, 07:27 PM   eBay Motors  #2 (permalink)
i run at the most 5 degrees above ambient at idle.
Surprise Duramax
Surprise,Arizona
2005 GMC
Old 11-20-2012, 11:13 AM   eBay Motors  #3 (permalink)
DMaxxrus's Avatar
Dont pull the wire out of the puddle so far.....sorry i had to
Looks good though. How noticeable is the scoop when your looking at the truck from a distance?
DMaxxrus is offline   Reply With Quote
Old 11-20-2012, 11:18 AM   eBay Motors  #4 (permalink)
bigjohn's Avatar
I did the same set up using black abs pipe ran it down to were the foglight would go.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
bigjohn is offline   Reply With Quote
Old 11-20-2012, 11:24 AM   eBay Motors  #5 (permalink)
How much does this actually help?
2004 White LB7 CCSB-Sold 4/5/13 onto bigger things!
Leveled w/ 1.5" Blocks
285/75/16 BFG AT w/ Moto Metals
Edge Juice w/ Attitude
AFE Intake
5" Diamond Eye Turbo Back Exhaust
6000k 35w DDM HID's - Hi's/Lo's/Fogs (w/ All on mod)
www.trollperformance.com
TNASH481 is offline   Reply With Quote
Old 11-20-2012, 11:27 AM   eBay Motors  #6 (permalink)
ALLY Cat's Avatar
Looks good but wouldn't work where I live, we get a "100 year" flood about every other year...
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, Ride Rites, LBZ turbo inlet mod, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is offline   Reply With Quote
Old 11-20-2012, 12:19 PM   eBay Motors  #7 (permalink)
signal13's Avatar
It helps a ton to get cold air to the engine instead of hot engine compartment air. Banks advertises a 39 h.p. gain with their cold air intake and superscoop. I was a little skeptical but immediately noticed a significant difference once installed. It just seems to run stronger. Highly recommend a cold air intake (and an air scoop as long as you aren't constantly driving through water over a foot deep) Mine has a drain on the other side to allow any water to run out.
07.5 GMC LMM SLE2, Z71 ECSB, ReadyLift 2" Kit, EFI Live-Autocal DSP5 by Idaho Rob, Magnaflow 4" downpipe back stainless exhaust w/DPF delete, Banks Ram Air Intake w/Super Scoop, Airlift 5000 Airbags w/In-cabin controllers, Retrax Tonneau Cover, Shocker Train Horns with 5 gallon on-board air and Viar Compressor, Bilstein 5100's, Line-X Bedliner, Mickey Thompson Baja ATZ's 285/70/17, Pulling Cedar Creek 36RE Touring Edition 5th Wheel, B&W Turnover Ball w/Companion Hitch
signal13 is offline   Reply With Quote
Old 11-20-2012, 12:36 PM   eBay Motors  #8 (permalink)
DenaliDuallyHD's Avatar
Did the same this with my old 2003 Banks Scoop:
2012 LML Denali Banks Super-Scoop Install
JohnnyO
2012 Denali Dually HD 4x4
Banks Exhaust, Ram-Air & Custom Super-Scoop
Line-X, BedStep, BedStep2, Bed Rug
B&W Turnover Ball Hitch with Companion 5th Wheel Hitch
American Work Cover-rolling cover/toolbox w/ B-light tonneau lighting system
1993 GMC 1500 SLE Extended Cab Short Box, 4x4, 5.7 gas, traded it for:
1996 GMC 3500 SLE Crew Cab Dually, 4x4, 7.4L gas, sold it and got a:
2003 GMC 2500HD SLT Crew Cab Short Box, 4x4, 8.1L gas, traded it in for the 2012.
DenaliDuallyHD is offline   Reply With Quote
Old 11-20-2012, 12:48 PM   eBay Motors  #9 (permalink)
The S.O.M.'s Avatar
Looks sweet, maybe I'll try to make myself one this weekend lol
The Sound Of Madness
2004.5 LLY ECSB
EFI Live, MA700 Trans, Airdog 2 165, MBRP 5" with 6” tip, Profab Downpipe, LML Manifold, LBZ Mouthpiece, AFE Stage 1 Intake, EGR Blocked, PCV Rerouted, Resonator Plugged, ADP Race Valve, MA Rear Housing Support, MA Pump Rub Fix, Rancho RS9000xl's, Amsoil Synthetics, Autometer Cobalt’s Boost & Pyro, Tint (5% back, 20% front), HID's, US Speedo Custom LED Gauge Cluster, Line-X’d rockers
To Come!! :
Profab EGR Delete
4094vvt
40% overs
The S.O.M. is offline   Reply With Quote
Old 11-20-2012, 04:47 PM   eBay Motors  #10 (permalink)
CanadianDmax's Avatar
I thought about making a similar setup. But I want to hide the intake side. Maybe I'll cut out the foglight holes and use that location. Great pics thanks for posting them.
2005 Chev 2500HD CCSB 4X4 LLY
Performance
Airraid intake,AFE Bladerunner,PCV Reroute.4"MBRP Turbo back,DiabloSport Predator 65hp (econo)
Sinister EGR Delete, Program by Westers Garage
Cosmetic
265/75R16 Goodyear Wrangler on Core wheels
Leveled, Debadged, Koolview tow mirrors
Truxedo bed cover
1987 Cavalier RS (Rusty Spot)
CanadianDmax is offline   Reply With Quote
