| updating heads on an lly? So I am pretty sure I have a leaking head gasket on my 05 with only 80k. I have herd there was a problem with the lly's warping heads? My question is... If I pay the 5k to have this fixed what are the chances of it happening again in another 80k or so? And can I have the heads updated to a better head and if so how much more will i be looking price wise? Thanks all!
__________________ 2005 GMC 2500 LLY |
| Senior Member Join Date: Feb 2011 Location: Fort Sumner, NM
| Just take them to machine shop for inpection, use grade C new headgaskets and ARP headstuds. Then u should be set bud.
__________________ 05' LLY 12.41 @109.9 Blake SDP Twinz, 40% overs, EFI-Live Props- Idaho Rob4'' Exhaust, Airdog, Traction Bars, Built Front End, Big Thanks to Dustin, Idaho Rob, and Scott 01' LB7 13.5@97 EFILive by me, Grade C HG, ARP studs, 4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans ![]() |
| Thanks! I appreciate the info. I am hoping the prob is with the EGR but knowing my luck it probley a head:-(
| What's the symptoms and what does the truck have on it as of modifications?? Is the coolant system pressurizing? Just trying to narrow it down for you.
| I'm That Guy... ![]() Join Date: Aug 2010 Location: Gilbert, AZ
| Form what I hear, head studs seem to solve the issue.
__________________ Tony Non Vendor contact information, URLs and/or links are NOT allowed in signatures or on forum! My opinion is not the opinion of Duramax Forum, Auto Forums, Auto Guide, or other Duramax Forum staff members! CLICK TO READ: FORUM RULES AND DF STAFF! Thank you Rob Coddens (Idaho Rob), Dustin @ ATP, Scott @ SDP, Kory Willis, and Mike L. for all of your help! Shhh... I sold my Dmax and I own a gasser now, don't tell anyone!!! I'll buy another Dmax soon, probably LLY or LBZ. |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Bypass the EGR coolant hose first, then if you still have issues it's probably your HG's. If you do the HG's be sure to have the heads pressure tested and checked for flatness, do a valve job (w/seals), use grade C HG's and ARP studs and the issue should be gone for good......good to change the water pump while you're in there too.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater |
| Thanks all! yes my cooling sys is pressurizing. no white smoke, no over heating issues. just puking coolant out the over flow bottle. the valve or whatever it is called is going to the turbo looks ok. iv noticed even after not running the truck for over 48 hours when i unscrew the overflow cap there is still quite a bit of pressure. I spoke with a tech here locally and he said he has done quite a few of these 05 dura's and the its a common problem with the HG's on # 5 and 7 cylinders. He told me he would replace them with the ARP studs, EGR delete, have the heads checked, all for around 3800.00 from what i have researched that seems to be a pretty good deal. He said he would do an actual diag on it before replacing them though. and thanks for the tip on having the water pump replaced while I am at it.
| mods on the truck are MBRP 5" turbo back. Bully Dog GT tuner, Air raid intake, and i believe that's about it.
| Junior Member Join Date: Jan 2009
| I haven't seen anyone comment about the heads themselves being an issue. It's the crappy gaskets and insufficient clamping force. Better gaskets and studs seem to solve the problem although it appears stock bolts with good gaskets hold up well if you aren't pushing the power with a programmer. I will likely do studs if and when my gaskets go even though I don't run a programmer. That said, not all LLYs loose their gaskets. There are a ton of LLY's out there without the problem but we only hear about the failures.
__________________ 2005 Chevy Silverado 3500LT SRW D/A CC/LB LLY 4x4 (loaded) LBZ MP, TxCAI, PS Cooler, stack seal, Edge Insight CTS, E837 Aux Radiator w/fan, Renodmax/Earl's Trans Cooler, Mass/IAT Shield, Fuel Cooler Fan, LML manifold NuWa Hitchhiker II LS 29.5LKTG 5th Wheel |
| | eBay Motors #10 (permalink) | |
| Quote:
That's pretty reasonable (ARP studs and EGR delete included) so if you don't do it yourself I would take him up on that. I would try and get him to do the water pump (TIG welded) at the same time while he's got the motor all torn down already. I would also switch over to EFI because the BullyDog may be part of the reason why the HG's went on your truck.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater Last edited by MTL_Dmax; 11-24-2012 at 03:41 AM. | |
