| (05 lly duramax with less than 80xxx miles)okay guys my truck started smoking white when its in gear at idle it doesn't do it when I'm in neatral its not a whole lot of smoke just enough to notice and see it in the mirror .. it doesn't run rough or miss or knock just puff out white smoke I checked all the injector balance rates and there all good ..could it be the fuel or cause of the cold weather? It started doing this once the weather changed ..please help I'm new to the site here and I'm still learning about the diesels thank you all in advance thank you |
| Creepy ![]() Join Date: Feb 2010 Location: Look out your window, see that van?
| moved to lly area did you check for any codes stored? welcome to DF .. ..
__________________ '07 LBZ '12 Express Van |
| Duramax Forum Supporter Join Date: Feb 2011
| Does your exhaust have a sweet smell to it? My guess is your egr may be leaking a touch of coolant into your exhaust. Mine did it along with many others. Mine would haze a touch of white and if i gave it some rpm's it would blow a bunch until all the coolant got burnt up. |
| Yes checked for codes and no codes are shown also check the coolant and its not low at all its at normal level and don't really have a sweet smell it smokes when its in drive but when I hit the gas it clears up but if I'm at a light or stop sign u can see it puffing white smoke... What you think ? Also thank you for such a quick respone |
| Salt sucks Join Date: Feb 2009 Location: Buckhannon,West Virginia
| Mine smoked when it was cold. Or if I had shitty fuel. checking balance rates. Get your return rates checked. need a tech 2 or pull the injectors and send them out.
__________________ Reger Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs Motor died 1/19/12 190.131 mi. Trans. died 7/27/12 200,136 mi. Built motor/Trans and tuned by Blackout Performance some parts to take it. 2011 30' Puma KDBSS |
| Maybe its the fuel I Usally get my fuel from sunoco gas station but this time I got it from a speedway and filled it up and that's when I really started to notice it smoking I guess ill just have to wait unrolled i burn all the fuel out and fill it up again and see what happens I hope to god that's all it is but its not running no different just puffing some white smoke ill keep my fingers crossed |
| put some poewr service in it. If its bad fuel itll help, check your fuel filter for water too, thatll wipe injectors right the out.
| K I will check that tomar morning and let u no what I find out thanks man |
| Senior Member Join Date: Aug 2009 Location: Des Moines, Iowa
| Diesels will puff white smoke in cold weather AND when the engine is cold. Does the smoke go away as the engine warms up?
__________________ 2005 Black Duramax Crew Cab Short Box Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's |
| | eBay Motors #10 (permalink) | |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| Quote:
I agree on the need to check return rates. Just as an aside, fuel return rates can't be checked with a Tech 2 since it's a physical test. Only way is to pull the return lines and measure at home or send them out to be tested.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater | |
